  4. Messed up on my build need radiator advice
46 Posts 5 Posters 8.6k Views
    @dan28
    The manual says that the cooling works by “thermo ~ syphonic action in conjunction with the pump”, but basically when the coolant in the cylinder sleeve is hot enough to actuate the thermostat and open up, the pump will move it. I don’t know any other motor that has the radiator physically above the motor to rely on heat rising through convection 🙄
    I guess I’m saying that I’d test run it with the rad mounted where you want it and see if it works. As long as the pump moves the coolant I don’t see any problem 😐
    I could be totally wrong though! 😜
    dan28
    @spookdog said in Messed up on my build need radiator advice:
    @dan28
    If you look at yours the water goes out the bottom rad hose along the metal pipe an to the water pump
    The problem I have using the dtr rad the water goes out the bottom hose an then has to travel upwards to the water pump
    A smaller radiator mounted higher up would solve the issue an the water would travel down as intended
    I m not sure how to add photos on here
    • D dan28
      @dan28
      @dan28
      The pump would still work and draw coolant up, it doesn’t rely on the coolant ‘falling’ down into the pump. It’s strong enough to lift fluid 2 foot. If it looks good, try it. If not do something that you like the look of!
      There is a tutorial on this site for posting pics, if I can suss it you can! I use a phone and imgur (app) to host mine. Do a search, please, it sounds like a wicked build!...
        @dan28
        dan28
        @spookdog I would rather it worked as yamaha intended so would like the radiator higher than the water pump
        I trail fitted the gas gas radiator it will fit but as it is approx 15cm shorter then there will be less coolant compared compared to how much is in The standard radiator not sure if that's going to be an issue
        • declanD
          @dan28 I doubt the coolant volume being an issue
            dan28
            @declan said in Messed up on my build need radiator advice:
            Would it not be the same as using your bike with a low coolant level as this radiator is 15cm shorter so quite a bit smaller
            S declanD 2 Replies Last reply
            • D dan28
              @dan28
              What country do you live in?
              • D dan28
                @dan28 no it wouldn't since the radiator will be filled to the top regardless so there's no air to expand
                  @dan28
                  dan28
                  @dan28
                  I m in the UK boss
                  • D dan28
                    @dan28
                    I m in the UK boss
                    @dan28
                    My temp gauge barely goes up a CM, only time it went up halfway was when the head gasket blew on the hot day (2 days ago). I could run a 15cm smaller radiator on my bike without heat issues.
                    Put a 12v fan on it with a temp probe to the radiator and it’d be fine, IMO...
                      @dan28
                      dan28
                      @spookdog after measuring the finned part of the gas gas radiator is only 15cm its literally half the size of the original
                      I remember callum saying he had issues with his bike running hot an he used the standard radiator
                      I would rather use a radiator closer to the intended size
                        @dan28 according to the vapor unit, it was sitting at 100 celcius in traffic. Which seems way too hot.
                        S D 3 Replies Last reply
                          @calum
                          I always thought ideal temp was as close to 100 as possible? That’s why the radiator cap is pressurised, to stop the coolant boiling but get it up there? I might be wrong, it’s been a long time since I looked into it and it was a car...
                          • declanD
                            #34
                            @spookdog not sure on my temp gauge when offroading in summer I would consider 110 Celsius to be time for cooling down since the motor would be smelling very hot
                              dan28
                              @calum said in Messed up on my build need radiator advice:
                              Using the twin rad setup that you have now how far up does it go when in traffic
                                @declan
                                It’s weird, my temp gauge doesn’t rise much at all in stop~start nightmare traffic. What does happen is my gear change gets ’sticky’, it won’t go into neutral without a struggle. That’s when my engine smells hot.
                                Trouble is a radiator is doing next to nothing if it doesn’t have any airflow forcing convection. Sitting in traffic is the worst possible scenario. I don’t have any cooling problems, if I did I’d put 1 or 2 12v fans on the radiator. The kind you get in computers for CPU cooling but bigger, there’s loads out there. have a temperature actuator probe that sits in the fins of the radiator, so they only come on when needed. If the problem was bad I’d shroud the fans th the radiator as well...
                                  @declan
                                  @spookdog the sticky gear changes might be your clutch overheating and putting pressure on the gearbox
                                    @declan
                                    Makes sense, especially when I ride the clutch like a numpty, rather than putting it in neutral, or just slowvertaking the stagnant traffic! 🙂
                                      @declan
                                      @spookdog meh clutches are dirt cheap and take 10 minutes to do and they last year's so just ride that clutch lol
                                        @declan
                                        I use it as a foot warmer in the winter!🥶
                                          @declan
                                          @spookdog yeah and the pipe is the hand warmer
