  4. Messed up on my build need radiator advice
46 Posts 5 Posters 8.4k Views
    @declan Start a build thread brah, I'm sure peeps would like to see your skills in action. 😉
    @ninja if you see my welds you would think different, maybe when it's running and riding I'll set something up
      dan28
      @declan looks good
      You have loads of room if mount the radiator in front instead of at the side
      • D dan28
        @declan looks good
        @dan28 I do without the exhaust it's a right hand radiator frame if I use a standard exhaust I'd have to get a different fuel tank and radiator plus seat set up so I'm going to build a simp me underslung exhaust
          dan28
          @declan what about the older exhaust from the lc models that mounts on other side
          I remember scrim mustang on here saying they can be used on dtr engine that way you can keep the radiator etc
          By the way can any one measure a lanza radiator for me
            @dan28 I have ordered a new one should be here in a few days, I will measure it when it arrives for you.
            They are tiny though.
              dan28
              @calum thanks calum
              • D dan28
                @calum thanks calum
                dan28
                @dan28 the dtr rad is approx 33cm long an 12 wide
                I have a gas gas txt rad it's 12 cm wide an approx 20 cm long
                What are peoples thoughts on this?
                Too small?
                • declanD
                  @dan28 I was looking at one of those on ebay,it would likely me okay if room allows adding a radiator fan would help too
                    dan28
                    @declan said in Messed up on my build need radiator advice:
                    its alot smaller though an the fan for the gas gas rad is expensive even for a used one
                    i need to find out the sizes of the ktm sx 50 rads both together they should be equalivent to the dtr rad i think
                    • D dan28
                      @dan28
                      The manual says that the cooling works by “thermo ~ syphonic action in conjunction with the pump”, but basically when the coolant in the cylinder sleeve is hot enough to actuate the thermostat and open up, the pump will move it. I don’t know any other motor that has the radiator physically above the motor to rely on heat rising through convection 🙄
                      I guess I’m saying that I’d test run it with the rad mounted where you want it and see if it works. As long as the pump moves the coolant I don’t see any problem 😐
                      I could be totally wrong though! 😜
                      S D 2 Replies Last reply
                        @dan28
                        More importantly though: where the fuck are the pics of a Dtr engine in a chop frame!! 🧐 Come on Dog!...
                          @dan28
                          dan28
                          @spookdog said in Messed up on my build need radiator advice:
                          @dan28
                          If you look at yours the water goes out the bottom rad hose along the metal pipe an to the water pump
                          The problem I have using the dtr rad the water goes out the bottom hose an then has to travel upwards to the water pump
                          A smaller radiator mounted higher up would solve the issue an the water would travel down as intended
                          I m not sure how to add photos on here
                          • D dan28
                            @dan28
                            @dan28
                            The pump would still work and draw coolant up, it doesn’t rely on the coolant ‘falling’ down into the pump. It’s strong enough to lift fluid 2 foot. If it looks good, try it. If not do something that you like the look of!
                            There is a tutorial on this site for posting pics, if I can suss it you can! I use a phone and imgur (app) to host mine. Do a search, please, it sounds like a wicked build!...
                              @dan28
                              dan28
                              @spookdog I would rather it worked as yamaha intended so would like the radiator higher than the water pump
                              I trail fitted the gas gas radiator it will fit but as it is approx 15cm shorter then there will be less coolant compared compared to how much is in The standard radiator not sure if that's going to be an issue
                              • declanD
                                @dan28 I doubt the coolant volume being an issue
                                  dan28
                                  Would it not be the same as using your bike with a low coolant level as this radiator is 15cm shorter so quite a bit smaller
                                  S declanD 2 Replies Last reply
                                  • D dan28
                                    @dan28
                                    What country do you live in?
                                    • D dan28
                                      @dan28 no it wouldn't since the radiator will be filled to the top regardless so there's no air to expand
                                        @dan28
                                        dan28
                                        @dan28
                                        I m in the UK boss
                                        • D dan28
                                          @dan28
                                          I m in the UK boss
                                          @dan28
                                          My temp gauge barely goes up a CM, only time it went up halfway was when the head gasket blew on the hot day (2 days ago). I could run a 15cm smaller radiator on my bike without heat issues.
                                          Put a 12v fan on it with a temp probe to the radiator and it’d be fine, IMO...
