  4. DTR 125 1994 help!?!
13 Posts 9 Posters 5.3k Views 1 Watching
  • JonathanLucaJ
    JonathanLucaJ
    JonathanLuca
    Hi folks,
    New to this forum and 2 strokes!
    I bought a 94 DTR off my uncle for £100 (been stood for 15 years) we got it running but dies when the revs go below 5k.
    Looking for a carb for a 94 model hasn't worked out, will a different year carb fit my bike?
    Any help would be appreciated.
    Next up I'll be asking about derestrcting haha
    Jonathan.
    dtlukeD 1 Reply Last reply
      Just wants to be refreshed.
      Strip the carb and give it a good clean. Clean the air filter. New plugs.
      • BurridgeB
        BurridgeB
        Burridge
        As Calum said just give the carb a good clean in petrol and make sure all the jets and drill ways are clear. It could be your pilot jet that's blocked, aswell as just replacing other consumables like plug and filter, and definitely petrol and 2t oil
        • AndyYamA
          AndyYamA
          AndyYam
          +1 on the above. and check the jets are standard.
          • 2
            2stroketerror
            Hi guys,it might not be just the jets,I have a Dt that when purchased it had stood for 10 years and the fuel goes like varnish and eats away inside th carb,have it ultrasonically cleaned by ur local bike shop and have it blown thru with a compressor as well ,then as the guys say above ☝
            • JonathanLucaJ
              JonathanLucaJ
              JonathanLuca
              Cheers for all your help guys. Carb is getting cleaned at my dad's work and getting put back on Friday so I'll let you know the outcome!
              • JonathanLucaJ JonathanLuca
                Hi folks,
                Jonathan.
                dtlukeD
                dtlukeD
                dtluke
                • JonathanLucaJ
                  JonathanLucaJ
                  JonathanLuca
                  Now then,
                  Got the carb back after it was stripped and cleaned and it kicks first time now but the revs go through the roof. Idle screw seems to have no effect, this bargain bike is looking less like a bargain day by day haha
                  • MightymanM
                    Usually means there is an air leak in the crank cases somewhere. The classic trick to confirm is to spray some wd-40 around the engine and see if the idling settles down a bit.
                      It's an Air leak, but try and renew the choke seal and gaskets in the carburettor body first. Runaway revs on idle indicate a lean condition. Is it harder to start?
                      Pilot Jet should be a 25. This determines the fuelling at idle and slightly over.
                      JonathanLucaJ 1 Reply Last reply
                        JonathanLucaJ
                        JonathanLucaJ
                        JonathanLuca
                        @Darty before the carb was given a good clean it would only start with a bit of spray through the air box. Now it starts first kick with the choke on but goes to about 5 - 6k revs and bogs down after that. Looked for a rebuild kit and it's near on £100!
                          Heres a rebuild kit for less that half that, including shipping: http://www.ebay.co.uk/itm/yamaha-dt-dtr-dtre-125-x-Mikuni-carb-Carburettor-repair-kit-dt-125-/272339199626?hash=item3f68ae668a:g:LSMAAOSw0UdXre0p
                          • JonathanLucaJ
                            JonathanLucaJ
                            JonathanLuca
                            Evening,
                            Just thought I'd let you know the bike is running sweet as a nut. Hadn't started in a day or 2 after it was idling at 3-4k. First kick this afternoon and it started and idles perfectly, it's mended itself!!
