  3. 3MB head.... Should I buy it?
18 Posts 8 Posters 7.2k Views 1 Watching
  • D Offline
    D Offline
    dtluke
    So after scouring the internet I found one for sale - in France... Its off a derbi bike but they use the same engines? Anyway. Would you buy this for £35? Does that head look damaged or just dirty?
    • D dtluke
      D Offline
      D Offline
      dtluke
      wrote on last edited by dtluke
      @dtluke wow, I actually managed to upload a photo! It's £24 for the head and £11 delivery from France.... A decent price but the ad says (impact to the combustion chamber) that's from google translate.... I'm guessing I should leave it but advice welcome as I would quite like a 3MB head!
      • MightymanM Offline
        MightymanM Offline
        You would need work done to that one... The pits in the centre are where loose metal has been smashed against it.
        D CalumC 2 Replies Last reply
        • MightymanM Mightyman
          D Offline
          D Offline
          dtluke
          @MIGHTYMAN hmmmm, sounds painful. J guess you can't sand it back too much as it'll take away the correct compression ratio?
            MightymanM Offline
            Not too sure on the specifics. But I imagine it would either be just about salvageable if the pits weren't too big, OR a specialist would have to actually build it up by adding ally back into it. Either way keep looking around and a cheaper option might pop up soon.
              D Offline
              D Offline
              dtluke
              @MIGHTYMAN Thanks. I agree - was just being hopeful someone would tell me it'll be fine 😉
                @MIGHTYMAN said in 3MB head.... Should I buy it?:
                That OR engine detonated. Detonation is engine killer.
                Absolute waste of money buying that head it's fucked. You would have to have it worked, in which case you might as well get the 3BN head worked
                • A Offline
                  A Offline
                  AndyYam
                  wanna buy a 4dl head?
                  DartyD D 2 Replies Last reply
                  • A AndyYam
                    DartyD Offline
                    DartyD Offline
                    @AndyYam Yes.
                    • A AndyYam
                      D Offline
                      D Offline
                      dtluke
                      @AndyYam is the 4DL as good as the 3MB? I've just put on my third head gasket now (Athena gasket) and still have a leak so I'm guessing my 3bn is warped anyway 😞
                      B 1 Reply Last reply
                        Look at this on eBay http://www.ebay.es/itm/302062068939
                          D Offline
                          D Offline
                          dtluke
                          @Calum thanks Calum, think I will go for that if you reckon its a good buy? I really can't find much info on the web about putting a 4dl head on a 3mb00 DTR barrel? I assume it will be an improvement over the 3bn - especially if minesl is warped!
                          N 1 Reply Last reply
                          • D dtluke
                            N Offline
                            N Offline
                            Great find @Calum
                            @dtluke Genuine Belgarda parts are the perverbial needles in hay stacks - nuff said!!! 😉
                            • D dtluke
                              B Offline
                              B Offline
                              Burridge
                              @dtluke said in 3MB head.... Should I buy it?:
                              Use a genuine Yamaha gasket when you put your new head on, a lot more money but it'll be worth it
                                The 4dl head sits on a 3mb barrel. Graham Bell says the head is where the majority of the power is made. Get that right and you can't go far wrong.
                                I have done many heads before and haven't had any problems with Athena. There is a tutorial on qhat you should do to prep the head and barrel using a sheet of glass and various grades of wet and dry paper. Do what I say in that turorial and it will seal.
                                • D Offline
                                  D Offline
                                  dtluke
                                  Cheers guys, I have bought that head. Looking forward to it arriving
                                  • A Offline
                                    A Offline
                                    AndyYam
                                    I think i have 1-2 4DL heads sitting around in the garage. I'm away for a week in Wales as of monday. If i have time before then ill get photos up in the for sale section. If not it'll be when i get back.
                                    What did that one on ebay go for? as a guide for price.
                                    • K Offline
                                      K Offline
                                      kennymurphy97
                                      Will a 1989 3MB head fit the 3MB barrel of my 2000 dt?
