  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 47.9k Views 2 Watching
    You cant run a Domed piston in a 4FU? Wouldn't it hit the head? I've got a 4FU head, and they never came with combustion rings, only 2RK/3BN's?
    A Flat top piston doesn't interfere with your transfer ports as much as a Domed piston, so you can take advantage of scavenging with correct porting and a proper exhaust,
    The 4FU seems to have larger volume crankcase transfers than a 3MB?
    I'm running .6mm squish and a 134cc heavy Top end porting on a 3MB barrel. Looking at 25bhp maximum on 97octane. Most power will be made by the cylinder head itself, the barrel is aiding it along.
    No doubt moving torque, and not that much more of it to very high RPM, will only make you come to be very efficient at going up and down the gearbox quicker to keep the thing in the right rev range.
    Depends what you want from it, i'd say get the ports cleaned up, but don't change the Port timings at all, and just run her standard. These engines don't make power at all like a Rotax!
    I've been bulding a race setup for mine for a while now, yet to know proper results tho
    @Darty Here was my 4FU
    As said I don't know natively if it supports domed, but certainly if you removed that ring and reworked the head
    DartyD 1 Reply Last reply
    • tdr125gregT
      tdr125gregT
      tdr125greg
      wrote on last edited by tdr125greg
        wrote on last edited by Darty
        https://c1.staticflickr.com/1/440/30800032804_7635f2db5c_c.jpg
        https://c1.staticflickr.com/1/431/31525983671_ea3ee375cf_c.jpg
        Mine might have been modified, the crown seems very different. No signs of a heavy skim. it's a closer match to a P' stamped head but with a squish height less than .5, A domed piston would crash into it at that point.
        A base gasket would help, but then you begin to change port timings, not good. I gave up on a 4FU, Nicasil is expensive if you lunch the bore up.
          Sorry my bad.
          I have had a few 4FU's and they have all been this way.
          Which is why I said it...
          • tdr125gregT
            tdr125gregT
            tdr125greg
            Another purchase sees the trail tech vapor and indicator dash added to PROJECT TDR.
            I purchased the kit on eBay from Moore speed racing for £150 all in which I thought was a good deal. 🔥🔥
            Any of you guys run the vapor on a tdr/Dt before?
            0_1488293323206_DSC_0017_1.JPG 😀
            • MightymanM
              #21
              I always thought replacing my TDR clocks with something like this would look a bit out of place as the stock one moulds nicely into the plastics. Bet theres a big hole there now! 😂
              tdr125gregT 1 Reply Last reply
              • MightymanM Mightyman
                tdr125gregT
                tdr125gregT
                tdr125greg
                @Mightyman I have thought about the same problem but how about 3d printing a new speedo surround then fibre glassing bondo, filler paint to finish ?
                MightymanM 1 Reply Last reply
                • tdr125gregT tdr125greg
                  @tdr125greg That is a very nice idea actually! Would be even better if you could save the fussing with fibre glass and just get a snug fit with something 3D printed.
                  • F
                    #24
                    Running a vapour on my DT. Homemade mounting bracket
                    • F
                      https://imgur.com/zi9671n
                        tdr125gregT
                        tdr125gregT
                        tdr125greg
                        @finnerz89 looks tidy mate, how responsive is the Rev meter and do you have the radiator temp sensor or the sensor that goes on the spark plug?
                        • F
                          Temp sensor that fits inside the radiator fin. I might get one for the plug and wire them through a switch
                            @tdr125greg vapor on my dt and I love it. Makes me feel like I got a spaceship at night with the shift lights flashing in my goggles. Haven't ridden the bike for years but back when I was a kid 🙂
                              tdr125gregT
                              tdr125gregT
                              tdr125greg
                              @Calum I'm really looking forward to seeing those shift lights in action
                                @tdr125greg The one I fitted to my MT-03 was SUPER inaccurate with the rev counter... I fitted it to the spark plug wire as the instructions mentioned but at 60mph+ speed the revometer would be all over the place, claiming I needed to shift all the time 😂
                                • F
                                  No problems with rev counter on mine, it's wired directly to the coil
                                    @finnerz89 Never had any problems with the counter myself.
                                    On my new build it csn be wired directly to the cdi
                                    F 1 Reply Last reply
                                      @Calum is that with the zeeltronic?
                                        @finnerz89 Yeah I believe it's the green/yellow wire that will pulse when the ignition fires. So no need to wrap the HT lead you can just wire it directly to the CDI.
                                        I would double check the wiring diagram first mind you.
                                          tdr125gregT
                                          tdr125gregT
                                          tdr125greg
                                          @Calum I've been in talks with borut at zeeltronic, and I have decided I will definitely order the cdi and the programmer within the next 2 months. I've seen many varied experiences using the Rev counter but I'm assuming that's down to a bad install as I've also seen the Rev counter work great..
