  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 42.8k Views 2 Watching
    @Darty Here was my 4FU
    As said I don't know natively if it supports domed, but certainly if you removed that ring and reworked the head
    DartyD Offline
    DartyD Offline
    wrote on last edited by Darty
    https://c1.staticflickr.com/1/440/30800032804_7635f2db5c_c.jpg
    https://c1.staticflickr.com/1/431/31525983671_ea3ee375cf_c.jpg
    Mine might have been modified, the crown seems very different. No signs of a heavy skim. it's a closer match to a P' stamped head but with a squish height less than .5, A domed piston would crash into it at that point.
    A base gasket would help, but then you begin to change port timings, not good. I gave up on a 4FU, Nicasil is expensive if you lunch the bore up.
      Sorry my bad.
      I have had a few 4FU's and they have all been this way.
      Which is why I said it...
      • tdr125gregT Offline
        tdr125gregT Offline
        tdr125greg
        wrote on last edited by tdr125greg
        Another purchase sees the trail tech vapor and indicator dash added to PROJECT TDR.
        I purchased the kit on eBay from Moore speed racing for £150 all in which I thought was a good deal. 🔥🔥
        Any of you guys run the vapor on a tdr/Dt before?
        0_1488293323206_DSC_0017_1.JPG 😀
        TDR125 🔥
        Put some respek on it! 😂
        • MightymanM Offline
          MightymanM Offline
          #21
          I always thought replacing my TDR clocks with something like this would look a bit out of place as the stock one moulds nicely into the plastics. Bet theres a big hole there now! :joy:
          tdr125gregT 1 Reply Last reply
          • MightymanM Mightyman
            tdr125gregT Offline
            tdr125gregT Offline
            tdr125greg
            @Mightyman I have thought about the same problem but how about 3d printing a new speedo surround then fibre glassing bondo, filler paint to finish ?
            TDR125 🔥
            MightymanM 1 Reply Last reply
            • tdr125gregT tdr125greg
              MightymanM Offline
              MightymanM Offline
              @tdr125greg That is a very nice idea actually! Would be even better if you could save the fussing with fibre glass and just get a snug fit with something 3D printed.
              • F Offline
                F Offline
                #24
                Running a vapour on my DT. Homemade mounting bracket
                • F Offline
                  F Offline
                  https://imgur.com/zi9671n
                    tdr125gregT Offline
                    tdr125gregT Offline
                    tdr125greg
                    @finnerz89 looks tidy mate, how responsive is the Rev meter and do you have the radiator temp sensor or the sensor that goes on the spark plug?
                    TDR125 🔥
                    • F Offline
                      F Offline
                      Temp sensor that fits inside the radiator fin. I might get one for the plug and wire them through a switch
                        @tdr125greg vapor on my dt and I love it. Makes me feel like I got a spaceship at night with the shift lights flashing in my goggles. Haven't ridden the bike for years but back when I was a kid :)
                          tdr125gregT Offline
                          tdr125gregT Offline
                          tdr125greg
                          @Calum I'm really looking forward to seeing those shift lights in action
                          TDR125 🔥
                            MightymanM Offline
                            MightymanM Offline
                            @tdr125greg The one I fitted to my MT-03 was SUPER inaccurate with the rev counter... I fitted it to the spark plug wire as the instructions mentioned but at 60mph+ speed the revometer would be all over the place, claiming I needed to shift all the time :joy:
                            • F Offline
                              F Offline
                              No problems with rev counter on mine, it's wired directly to the coil
                                @finnerz89 Never had any problems with the counter myself.
                                On my new build it csn be wired directly to the cdi
                                F 1 Reply Last reply
                                  F Offline
                                  F Offline
                                  @Calum is that with the zeeltronic?
                                    @finnerz89 Yeah I believe it's the green/yellow wire that will pulse when the ignition fires. So no need to wrap the HT lead you can just wire it directly to the CDI.
                                    I would double check the wiring diagram first mind you.
                                      tdr125gregT Offline
                                      tdr125gregT Offline
                                      tdr125greg
                                      @Calum I've been in talks with borut at zeeltronic, and I have decided I will definitely order the cdi and the programmer within the next 2 months. I've seen many varied experiences using the Rev counter but I'm assuming that's down to a bad install as I've also seen the Rev counter work great..
                                      TDR125 🔥
                                        MightymanM Offline
                                        MightymanM Offline
                                        @tdr125greg Yeah don't take my experience as fact, I expected that it wasn't the norm.
                                        CalumC tdr125gregT 2 Replies Last reply
                                          @Mightyman Way back when, When I took my bike license before the law changed, I did it on my DT.
                                          There is a bit where you must do national speed limit. Guess what? Vapor packed up. Looked down and I was doing 110 MPH I was like WTF! Bike only does 70 lol.
                                          I have had glitches sure, but the norm is that it is spot on.
