  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 45.8k Views 2 Watching
  • tdr125gregT tdr125greg
    I could I guess but that would mean extending the aprilia's steering stem as it's very identical in length to my standard steerer length???
    @tdr125greg Identical length ey?
    Just go onto Simply bearings and buy thr right size bearings.
    Mate might have just stumbled on the easiest USD conversion!
    • tdr125gregT Offline
      tdr125gregT Offline
      tdr125greg
      wrote on last edited by tdr125greg
      #55
      I put alot of research into finding a suitable front end as there was alot of options.
      Firstly I was going to use yz forks as the bottom half of the stem was 30mm in diameter but soon realised thanks to you guys I would need a cup made up, that itself wouldn't be a major issue but then the process of having to properly shorten them (deltaboxframe angles) and then progressive springs and revalving.....
      To me that seemed like a right ole Ballache and so started looking at factory sm 125's that came with Usds following the format of having a 17mm wheel spindle, 3.0/3.5 front wheel width and stem diameter length in relative to my standard OEM steerer. This lead to me riejue and aprilia forks then luckily enough a set of aprilia Marzocchi's came up on fleabay and I just couldn't say no to them for a measley 55GBP posted!!!
      The aprilia MX standard used 25/52 top and bottom
      My tdr takes 25/43 top and a 30/55 bottom
      @Calum what's your thoughts on a 25/43 top and 25/52 bottom with maybe a sleeve welded into the bottom of the frames headstock to seat it all tightly??.. Or..... A 28/55 on bottom with maybe one of these.
      TDR125 🔥
      Put some respek on it! 😂
      ZrakoZ 1 Reply Last reply
        ZrakoZ Offline
        ZrakoZ Offline
        Zrako
        wrote on last edited by Zrako
        #56
        @tdr125greg could you please explain me what exactly did you meant by ...."Firstly I was going to use yz forks as the bottom half of the stem was 30mm in diameter but soon realised thanks to you guys I would need a cup made up, that itself wouldn't be a major issue but then the process of having to properly shorten them (deltaboxframe angles) and then progressive springs and revalving..... " ??
        Im going for the yz forks and Im bit confused 🤔
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
          tdr125gregT Offline
          tdr125greg
          #57
          @Zrako The yz steering stem is longer than the stem on my chosen forks therefore I do not need/have the space to consider the upper bearing cup.
          My tdr frame does differe to the frame Of the Dt.
          Your best bet for information regarding the bearing cup method can be found on the forum thanks to @Calum
          That's your Bible near when it comes to a yz fork swap on a Dt 🙂 even @gareth_iowc references Calum's method for his project 👌👍👊
          TDR125 🔥
            ZrakoZ Offline
            ZrakoZ Offline
            Zrako
            @tdr125greg yeah I've read it couple of times thats why I was confused . Thanks mate
            • G Offline
              G Offline
              gareth_iowc
              wrote on last edited by gareth_iowc
              #59
              @Zrako calum's method works great. i've got some close up pictures so you can see how it works
              https://dt125r.co.uk/topic/595/project-i-can-t-leave-things-alone
              i used a stock dtr lower bearing in the frame with the yz forks and the stock yz top bearing sat in the new bearing cup 🙂
              DT125R 2000
              DRZ400 2006
              Golf Mk3 20v Turbo 1996
                tdr125gregT Offline
                tdr125greg
                OMG IS THAT A ROLLING CHASSIS BRO???
                Not quite!!!!but it does give an idea to how she will sit, I'm so happy with how things are planning out so far on this project for now though
                I'm still looking for a tidy wr200 rear swinger and a nice piggy back gas shock (which one I'm still undecided on).
                Enjoy
                TDR125 🔥
                N 1 Reply Last reply
                3
                  Enjoy
                  N Offline
                  N Offline
                  @tdr125greg Sure looks sweet there bud, I love the polished ali look myself and would keep it all that way! Not sure if you said it before but are you going for the SM look or not? That bike with high mudguards would look unique and much like a CRF me thinks. 👍
                  tdr125gregT 1 Reply Last reply
                  • N NINJA
                    tdr125gregT Offline
                    tdr125gregT Offline
                    tdr125greg
                    @CYBER-NINJA said in TDR125 4GW:
                    @CYBER-NINJA yeah man Polisport SM line fender and a front mask headlight. as much as would like to have my frame all polished and dam bro iv thought so many times about polishing it i always come back to how schweeet and how much less maintenance it would be to have the chassis powder coated in a graphite/slate grey
                    TDR125 🔥
                      N Offline
                      N Offline
                      #63
                      @tdr125greg Too true, you can protect polished stuff with ACF50, which does a cracking job of protecting it for-sure;
                      http://www.ebay.co.uk/itm/201703863031?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                      But hey I hear what your saying with the powder coating and at least your sticking with the silverish theme. I'm sure she will look sweet once your done and be unique as I said before. 😉
                      • N NINJA
                        tdr125gregT Offline
                        tdr125gregT Offline
                        tdr125greg
                        @CYBER-NINJA as regards to polished goodies though i do have a few bits to go on 😉 i intend to have completely polished engine cases and so i will definitely need to look into a product for protection cheers buddy it means a lot.
                        TDR125 🔥
                          N Offline
                          N Offline
                          @tdr125greg Which colour are you going for with the tank and fenders? Are you gonna keep the wheels black too???
                          • MightymanM Offline
                            MightymanM Offline
                            The frame isn't ali though surprisingly
                            CalumC N 2 Replies Last reply
                              tdr125gregT Offline
                              tdr125greg
                              @CYBER-NINJA yeah man wheels will stay black for sure . and now you have mentioned HONDA CR thoughts of a CR tank and rad aare Overloading my mind lol im guessing the only issues would be mounting points???...
                              and as far as panels go they will be a shade of blue but as of yet iv still not choosen THE ONE that stands out for me .....
                              TDR125 🔥
                              • MightymanM Mightyman
                                @Mightyman Right, I was thinking this myself...
                                  N Offline
                                  N Offline
                                  @Mightyman Shiney steel - all polished up then!!! 🙂
                                  • G gareth_iowc
                                    ZrakoZ Offline
                                    ZrakoZ Offline
                                    Zrako
                                    @gareth_iowc awesome mate , defo will do the cup. What material did you used?
                                    Btw what you planning to do with the other yz engine? 😁
                                    • G Offline
                                      G Offline
                                      gareth_iowc
                                      @Zrako the guy made it out of alloy 🙂
                                      The 1lx is up for sale 😜
                                      DT125R 2000
                                      DRZ400 2006
                                      • G gareth_iowc
                                        ZrakoZ Offline
                                        ZrakoZ Offline
                                        Zrako
                                        @gareth_iowc I was wondering if alloy is good.
                                        • ZrakoZ Zrako
                                          @Zrako It's going to be softer than steel, the head stock can take a battering as well, it's under some levels of force. But I'd imagine it would be fine. After all the aprilia is an Alloy Frame/Headstock.
                                          So it should be up to the task fine.
