  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 47.3k Views 2 Watching
  • MightymanM Mightyman
    The frame isn't ali though surprisingly
    @Mightyman Right, I was thinking this myself...
      @Mightyman Shiney steel - all polished up then!!! 🙂
      • G gareth_iowc
        @Zrako calum's method works great. i've got some close up pictures so you can see how it works
        https://dt125r.co.uk/topic/595/project-i-can-t-leave-things-alone
        i used a stock dtr lower bearing in the frame with the yz forks and the stock yz top bearing sat in the new bearing cup 🙂
        ZrakoZ
        ZrakoZ
        Zrako
        @gareth_iowc awesome mate , defo will do the cup. What material did you used?
        Btw what you planning to do with the other yz engine? 😁
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
        • G
          G
          gareth_iowc
          @Zrako the guy made it out of alloy 🙂
          The 1lx is up for sale 😜
          DT125R 2000
          DRZ400 2006
          Golf Mk3 20v Turbo 1996
          ZrakoZ 1 Reply Last reply
          • G gareth_iowc
            ZrakoZ
            ZrakoZ
            Zrako
            @gareth_iowc I was wondering if alloy is good.
            • ZrakoZ Zrako
              @Zrako It's going to be softer than steel, the head stock can take a battering as well, it's under some levels of force. But I'd imagine it would be fine. After all the aprilia is an Alloy Frame/Headstock.
              So it should be up to the task fine.
                ZrakoZ
                ZrakoZ
                Zrako
                @Calum yeah thats sounds about right but also alloy frames have pressed steel inserts in them. Well , will turn one as I get the forks 😄
                • tdr125gregT
                  tdr125gregT
                  tdr125greg
                  • tdr125gregT
                    tdr125gregT
                    tdr125greg
                    repost
                    https://www.youtube.com/watch?v=Rl2sXLhRuSU
                    DartyD 1 Reply Last reply
                    3
                    • tdr125gregT tdr125greg
                      repost
                      @tdr125greg
                      Perhaps finish the project first 😂 ✌🏽
                      Love the polished bits tho, thats cool.
                      • MightymanM
                        Aha that's awesome!
