tuningdtryamaha2003wr200
254 Posts 25 Posters 243.6k Views 6 Watching
  • Louis-DT-WRL Louis-DT-WR
    [[topic:post-is-deleted]]
    @Louis-James It's up to you, it's your build thread, display the information however you want.
    I'm sure my build has got more photos than yours and I managed alright. It's something I took pride in.
    One thing I did was move all of the photos off the first post, so that the page can load and then you can load the photos later. But I sort by latest post. I also moved all the build pictures into one post so it was just a continuous blog.
    But each to their own.
    DartyD 1 Reply Last reply
      wrote on last edited by Darty
      #110
      @Calum Just to butt in a sec,
      I've noticed my Flickr links are not embedded anymore, and wont do so..
      I will have to go through and re link every one from a different hosting site?
        @Darty No they probably just need embedding properly.
        • Louis-DT-WRL
          Louis-DT-WRL
          #112
          Got a few small but satisfying jobs to do.
          Fit the 17t front sprocket to gear up.
          Fit stronger clutch springs (uprated wr200 ones)
          Coolant and oil change.
          Custom thicker core alloy radiator.
          Replace LH crank case cover with a silver one to match.
          General fine tune and visual tweeks.
          I have it on the bench next to a standard one with a spare sub frame bracket. Bottom hose connector needs repositioning. Mounting brackets need welding on and also for the guard
          • Louis-DT-WRL
            Louis-DT-WRL
            #113
            Starting the fabrication, sits very nicely in the sub frame. Removed hose connections and prepped new ones to be welded on (and weld the big hole)
            Then I'll fabricate new brackets to take the old rubber mounts. Also checked the clearance for when it's on the bike. Should be plenty room before hits the fuel tank.
            Fabricated the two mounting brackets. Jigged it up using the subframe to ensure it's not going to rub. It will be free floating on the rubber mounts as it should.
              @Louis-James This ought to make a nice difference in cooling!
              Just for anyone else wondering a single ally rad is going to be much more performant than twin iron rads.
              Just have to be careful not to cool the engine by too much else you'll heat seize the engine on long runs.
              • Louis-DT-WRL
                Louis-DT-WRL
                Hopefully @Calum, still was running alright on my standard radiator for the wr200 motor even though it has 2 as standard.
                What do you mean by iron? Who would fit that? Would be heavy as.
                  @Louis-James Stock brass or steel or whatever the original radiators are made from. I know on cars they tend to be brass.
                  On the Starlets you can get way with running a radiator half the size if it's an ally one as it dissapates heat so much better.
                    Louis-DT-WRL
                    Louis-DT-WRL
                    Also to note, this core may be 10mm shorter but has 11 cooling tubes and not 8. Also 20mm thicker
                    • MightymanM
                      Love these sort of mods. Very well engineered upgrade right there 👍
                      • MightymanM Mightyman
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Mightyman cheers. I like to get things done 🙂
                        • ZrakoZ
                          ZrakoZ
                          Zrako
                          Looks awesome. Cant wait to see it finished.
                          1979 Jawa Mustang 50
                          2003 Gilera DNA 125 R.I.P
                          2015 Keeway TX 125 SM
                          2006 Yamaha DT 125 X
                          • Louis-DT-WRL
                            Louis-DT-WRL
                              It's looking sweet bud.
                              • CallumJ94C
                                CallumJ94C
                                CallumJ94
                                This has gotta be one of the best DTR's I've seen! Absolutely stunning mate 👌 A load of great work here. Have you had it on a dyno?
                                I didn't realise until I looked back through the thread that I bought your old tank panels off of eBay last year. Still look good, although the RH one is now Drift Stitched from a bad knock 😂
                                • CallumJ94C CallumJ94
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @CallumJ94 thanks callum. Oh really haha, they were good condition for age. Just wanted to make it perfect
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    #125
                                    Ohh my insurance policy came today.
                                    Since I've invested so much time and money into this bike, I bought a spare heart!
                                    Because the cylinder it has now is 22 years old on standard size, as it is nickasil plated.
                                    The new one is also plated and honed.
                                    Proper DT porn here
                                      Wow, dare I ask how much!!!
                                        Louis-DT-WRL
                                        Louis-DT-WRL
                                        @Calum Claimed the vat back through families company but £318 excluding vat.
                                        One-day there will be none left.
                                        Had a end of tax year bounty from HM 🙂
                                          @Louis-James That's actually really cheap.
                                          Yes you are right Louis, however there will always be better engines to transplant should that be the case.
                                          Hell even electric engines are far superior to most petrol motors/.
