Dtr125 powervalve help
Having trouble wireing powervalve on my dtr125 engine fitted into kx125 frame engine only kickstart servo is 5 wire servo cdi has 3 spare wires ???
Have no idea first 2 stroke ive had had alil troble getn engine to fit.but all in n running jst dnt sound good seems to lack revs power not rode yet waitn on new sprocket n chain
@ijohney123 I'de like to see some pictures if you have any, would be interesting seeing how you've mounted the engine.
No spare wires from cdi are blue n light blue in sam connector n a yellow black on its own tryn upload pic avn trouble have a spare 4 wire plug coming from engine
Tryed 2 open srrvo with a 12v battery and cant seem to get it to do anything
spare wires cdi -
servo wires
spare wire from engine
wire from cdi to coil -
I need a control unit for may servo
look like tht trying to find 1 anybody know any1 stripping 1 ? -
Can you not just get the CDI that will do both the ignition and servo.
I run a Zeeltronic on mine, which is hands down the best bang for buck in terms of performance. Gives you complete control over the YPVS operation.
@Calum how much u unit
If you have a 5 wire loom, then YPVS is controlled via the single CDI unit, you should be looking for a 3RM -?
Seperate Servo controllers were one year only on the DT125R back in 1988. 3 wire looms,
@Darty u hav 3gm cdi is this all i need
Theirs a few on eBay
