  3. Carburetor
  4. Help im new to this bike but its costantly flodding any help where do i start ?
15 Posts 6 Posters 4.0k Views 1 Watching
  • rogeringR Offline
    rogeringR Offline
    rogering
    Help crank is filling with fuel
    • Louis-DT-WRL Offline
      Broken float switch and blocked overflow?
        Check petcock and the float in the carb
        • rogeringR Offline
          rogeringR Offline
          rogering
          wrote on last edited by rogering
          Right guys I've got it running after my first full engine rebuild, problem I'm having now is the bike starts fine can get it rev flat out then it seems like it was having too much fuel so I turned my peacock of and it started to pick up again before screeming then I turn fuel on and goes ok then bogs I full throttle it fells like its just over idling anyone know what's the issue I'm hoping it's the carb and if I turn my peacock half off it seems fine lol
          Many thanks for any help
          • MightymanM Offline
            MightymanM Offline
            Obvious one for over revving is an air leak but if it's fine when cold, not too sure.
            • rogeringR Offline
              rogeringR Offline
              rogering
              It seems fine with my petcock half off if that helps
                I have seen this before when the throttle is not shut off properly.
                Make sure the cable is routed properly and the carb is completely shut. If it checks out okay then I wouls be looking at a leak somewhere. A can of WD40 will help isolate the problem. Spraying in the usual cases, carb inlet and left hand crank seal. It should idle properly for a moment when you soak the air leak.
                • rogeringR Offline
                  rogeringR Offline
                  rogering
                  No leaks or cables dodgy all new and tested it's idling fine just when I throttle it it won't pick up revs until I turn petcock off then goes fine until it empty then revs I turn tap back on it goes fine again and dose the same boggy full throttle but if I turn tap half way off the bikes perfect so I'm thinking too much fuel so how do I solve and check please help
                  • rogeringR Offline
                    rogeringR Offline
                    rogering
                    I'll go and take pic of carb in 15 mins if that helps because I know it ain't the stock square ones I see it's a round screw kind
                    • rogeringR rogering
                      @rogering Choke isn't locked on is it?
                      • rogeringR Offline
                        rogeringR Offline
                        rogering
                        Choke is fine mate I can see it open and close when I cleaned it out just seems like its dumping too much fuel in what would that be ? As I don't think it's the right carb for the bike tbh
                          @rogering Open up the air screw then.
                          It doesn't really mattee what carb you got, so long as it set up properly.
                          I posted a blog on here about how to sey it up properly.
                            NINJAN Offline
                            NINJAN Offline
                            @rogering If it's just flooding turn the petrol OFF and crank it 10-12 times with no throttle. Then let it sit for 2-3 mins, then turn the petrol back on and start as normal. That should help get rid of the over fueling.
                              Verify that the float height is correct
                              • rogeringR Offline
                                rogeringR Offline
                                rogering
                                I was going off float hight for a dtr when it was a Dt 2 mil difference and just realised the pod filter was batterd and was restricting air flow all good now cheers guys
