  3. Carburetor
  4. Help im new to this bike but its costantly flodding any help where do i start ?
15 Posts 6 Posters 4.6k Views 1 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Broken float switch and blocked overflow?
      Check petcock and the float in the carb
      • rogeringR
        rogeringR
        rogering
        wrote on last edited by rogering
        Right guys I've got it running after my first full engine rebuild, problem I'm having now is the bike starts fine can get it rev flat out then it seems like it was having too much fuel so I turned my peacock of and it started to pick up again before screeming then I turn fuel on and goes ok then bogs I full throttle it fells like its just over idling anyone know what's the issue I'm hoping it's the carb and if I turn my peacock half off it seems fine lol
        Many thanks for any help
        • MightymanM
          Obvious one for over revving is an air leak but if it's fine when cold, not too sure.
          • rogeringR
            rogeringR
            rogering
            It seems fine with my petcock half off if that helps
              I have seen this before when the throttle is not shut off properly.
              Make sure the cable is routed properly and the carb is completely shut. If it checks out okay then I wouls be looking at a leak somewhere. A can of WD40 will help isolate the problem. Spraying in the usual cases, carb inlet and left hand crank seal. It should idle properly for a moment when you soak the air leak.
              • rogeringR
                rogeringR
                rogering
                No leaks or cables dodgy all new and tested it's idling fine just when I throttle it it won't pick up revs until I turn petcock off then goes fine until it empty then revs I turn tap back on it goes fine again and dose the same boggy full throttle but if I turn tap half way off the bikes perfect so I'm thinking too much fuel so how do I solve and check please help
                • rogeringR
                  rogeringR
                  rogering
                  I'll go and take pic of carb in 15 mins if that helps because I know it ain't the stock square ones I see it's a round screw kind
                  • rogeringR rogering
                    @rogering Choke isn't locked on is it?
                    • rogeringR
                      rogeringR
                      rogering
                      Choke is fine mate I can see it open and close when I cleaned it out just seems like its dumping too much fuel in what would that be ? As I don't think it's the right carb for the bike tbh
                        @rogering Open up the air screw then.
                        It doesn't really mattee what carb you got, so long as it set up properly.
                        I posted a blog on here about how to sey it up properly.
                          @rogering If it's just flooding turn the petrol OFF and crank it 10-12 times with no throttle. Then let it sit for 2-3 mins, then turn the petrol back on and start as normal. That should help get rid of the over fueling.
                            Verify that the float height is correct
                            • rogeringR
                              rogeringR
                              rogering
                              I was going off float hight for a dtr when it was a Dt 2 mil difference and just realised the pod filter was batterd and was restricting air flow all good now cheers guys
