  4. Temp gauge trouble shooting
103 Posts 10 Posters 43.0k Views 1 Watching
  • declanD Offline
    I have no idea how this system works the plugs there plugged in and doesn't work if someone would like to educate me or help trouble shoot this it would be much appreciated
      It's a thermistor.
      Read about it.
        It's a thermistor.
        Read about it.
        @calum do the thermistors generals go bad? They seem like gold dust
        CalumC D 2 Replies Last reply
          @declan Thermistor: an electrical resistor whose resistance is greatly reduced by heating, used for measurement and control.
          I presume that's how the DTR does it.
          Yes they will eventually fail like most things. It's the cheapest place to start looking.
          Simple to test, measure it's resistance cold, heat it up, measure it's resistance hot.
            @calum I'll look into it thank you Calum
            • MightymanM Offline
              MightymanM Offline
              If it hasn't worked since you first got the bike, you may have the wrong one installed. There are two different types.
              declanD 2 Replies Last reply
              • MightymanM Mightyman
                @mightyman looks pretty old guy said that it was working but he was a compulsive liar so I highly doubt it
                  @declan the needle moves in the clocks when the key is turned so I know that works
                    @mightyman do any of you lads recommend any other systems like universal temp gauges
                      I have an universal temp gauge on my radiator, wrosk good.
                      Goes on pretty hard, but fits both my Dt and my wr250r
                      http://www.ebay.com/itm/Universal-1-3-Bar-Thermo-Thermostatic-Radiator-Cap-Cover-Water-Temperature-Gauge/371712652878?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                      terry.tzT declanD 2 Replies Last reply
                      • NottsbikerN Offline
                        NottsbikerN Offline
                        How hot is the bike running?
                        Might be a daft question but is it getting hot enough to show on the gauge. I seem to remember my previous DT-R's would run just under halfway on the gauge.
                        • NottsbikerN Nottsbiker
                          @nottsbiker If the themostat has been removed, then it's going to take a VERY long time to warm up.
                          Very bad for engines running without a thermostat.
                          • J Jens Eskildsen
                            terry.tzT Offline
                            terry.tzT Offline
                            terry.tz
                            @jens-eskildsen thank you for that I'm going to get one as one it looks cool and mine rises but its never ever above 1/8-1/4 on the gauge might be the thermostat is not reading right anymore but it could be fine so thanks
                              NottsbikerN Offline
                              Sorry only skim read
                              Yes is going to take for ever to get up to operating temperatures with no stat
                                Sounds right with the reading, mine is just above where the line in the display starts to thicken, but will get hot in deep sand or slow technical trails.
                                Photo for clarification, mine is usually well below this reading:
                                https://i.ytimg.com/vi/QkRvx66dWc0/maxresdefault.jpg
                                terry.tzT 1 Reply Last reply
                                • J Jens Eskildsen
                                  terry.tzT Offline
                                  terry.tzT Offline
                                  terry.tz
                                  @jens-eskildsen mine don't get that far even when I been off road but I am running pure water doubt it could make that much difference but we will see as I'm getting one anyway they look good 😀
                                  • terry.tzT terry.tz
                                    @terry-tz mine doesent read at all and my bike warms up real quick faster than my 4 stroke it gets really hot but just seems that it's the way the engine likes it tbh since I don't cruise any where it's always full throttle If the roads clear
                                      terry.tzT Offline
                                      terry.tzT Offline
                                      terry.tz
                                      @declan ye same and I'm not sure I think it moves a tiny bit il take a photo and just look like a d!ck later and keep at in the band everywhere I go I can imagine the looks now when I'm at traffic lights with my purple helmet 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆 😆
                                        @terry-tz 😂😂😂😂
                                        • J Jens Eskildsen
                                          @jens-eskildsen does yours sit on 20 when cold why does it do this they all seem to?
