  4. Autolube pvc see through pipe bubbles
30 Posts 7 Posters 6.7k Views
  • Sgt Robuck 5S Offline
    Sgt Robuck 5
    I've recently put see through pvc pipes on my autolube pump and the pvc pipe from the pump to the carb seems to have many small bubbles and a few big ones. I've still got premix in the bike as well and haven't been for a decent enough ride yet, is that all it needs?
    • F Offline
      F Offline
      You can bleed the pump, but if you're running premix as well you'll probably be fine.
      • Sgt Robuck 5S Sgt Robuck 5
        @sgt-robuck-5 yeah just take it for a ride it should sort it make sure your using autolube freindly oil
          Sgt Robuck 5
          @declan Will do tomorrow for a good 20mins
            I wouldn't worry about it. So long as the bubbles move out and don't become bigger or more frequent in nature.
            That's one of the perks for running clear tubing, you can see what's going on.
            • ZrakoZ Offline
              ZrakoZ Offline
              Zrako
              As long as you dont have bubbles from oil tank to the pump it will be fine
              1979 Jawa Mustang 50
              2003 Gilera DNA 125 R.I.P
              2015 Keeway TX 125 SM
              2006 Yamaha DT 125 X
              • J Offline
                J Offline
                Jens Eskildsen
                What they said, just ride it ๐Ÿ˜ƒ
                • Irongamer727I Offline
                  Lending the thread a bit. As I have switched to clear oil lines, I am going to bleed the little sucker. My idea is, to speed things up, to disconnect the throttle cable running to the pump and manually open it fully. Thereby not having to wait forever and ever before the air is gone. Thoughts? Mind I have a brand new cylinder. (Of course running premix until bled)
                  • Irongamer727I Irongamer727
                    @irongamer727 just leave it as is itโ€™s not a long process the revs help too itโ€™s not all about throttle position
                      @declan it's quite an easy undertake though. Should work.
                      • J Offline
                        J Offline
                        Jens Eskildsen
                        You can open the pump without disconnecting the cable. Just push the pump open with a finger. All you need to do is remove the cover to the pump.
                        • J Jens Eskildsen
                          @jens-eskildsen you think it would work?
                          F 1 Reply Last reply
                            F Offline
                            F Offline
                            @irongamer727 it's what the workshop manual says to do ๐Ÿ‘
                              I am thinking of something like this. https://youtu.be/FytKDA4AqEE
                                @irongamer727 yes using your finger will work but sometime it causes the Rev cable junction to screw up so you have to take your tank off and sort the cables out it happen everytime I do it it even sometimes throws the Rev cable out the carb
                                  @declan not an issue as the bike is already teared down after top end swap.
                                    @irongamer727 all good then
                                      @declan literally took 1 minute to "bleed". Didn't even bother to use the bleed screw. All good now๐Ÿ‘ u also running clear hoses?
                                        @irongamer727 from pump to manifold yeah when I have time I hope to change tank to pump as the hose is old and itโ€™s pretty much plastic itโ€™s that old it will crack if your not careful
                                          @declan allright, but why? As you already have a clear oil pipe from the pump, I don't see the benefits of having the entire feeder hose transparent?
