  3. Other
  4. CB750 scrambler project
139 Posts 11 Posters 68.3k Views 2 Watching
  • Louis-DT-WRL Offline
    Louis-DT-WR
    Working through the electrics. I've got my rear indicators and tail lights sorted.
    I made a CDI holder to relocate it.
    Fuse box and indicator regular relocated.
    Front lights, indicators and horn on.
    Ignition barrel relocation plate made.
    Just sorting a battery box and the battery is on order. I can't fully test what connector goes where until the battery comes.
      Louis-DT-WR
      Well I put the engine in alone which was a very heavy task 💪 killed my back haha. Lining it up with the mounts while the bike was leaning again the bench. (You can't fit the engine when the chassis is on a bike lift)
      Got my battery box mounted with the lithium battery. Its so light! I thought it was just a empty case!
      Carbs on + filters and cables. Fitting the carbs was tricky, the rubber manifolds are so hard. I'd replace them but £150+vat for 4 and they're not cracked.
      • Louis-DT-WRL Louis-DT-WR
        Louis-DT-WR
        I even have a engine lift but it would have needed an offset cradle made up to clear the frame
          That does look smart as f to be fair!
            Louis-DT-WR
            @Calum cheers man. Its literally a case of getting parts in my hands and making it fit/fabricate parts. I wish fowler's would hurry up, waiting ages for my rear brake parts. And side stand bits
              Louis-DT-WR
              Little bits done, oil cooler fully connected, the pipes were bent, took a while to get them right.
              Oil filter came finally.
              PCV filters on.
              Started seat mounts and ignition switch relocation.
              The 2 most expensive items I need is an exhaust and starter motor.
              Still undecided what tank colour. I'm thinking Matt gunmetal grey. I was going to go black but think that would be over kill.
              declanD N 2 Replies Last reply
                PCV filters on.
                @Louis-DT-WR match your tank to the cam covers maybe
                  PCV filters on.
                  @Louis-DT-WR You'll be too scared to get that beast dirty for-sure!!! 😂
                    Louis-DT-WR
                    @declan satin silver would be nice but not too stealth.
                    • N NINJA
                      Louis-DT-WR
                      @NINJA always the case but haven't gone OCD on this. Its got scratches and scruffs on the engine and forks. And I like it looking ragged
                        Louis-DT-WR
                        Lights check on.
                        Tail lights seem to have not power, maybe but headlight is on when ignition on. Brake lights not working 🤔 maybe it will when engine is running.?
                        Horn was faulty,
                        All 4 indicators would flash, so I had it wire in a diode and earth the dial indicator light
                        Clutch hydraulic line arrived and installed.
                        Tank painted, I have a decal coming for it.
                        Ignition switch installed
                        R 1 Reply Last reply
                          Lights check on.
                          Horn was faulty,
                          R Offline
                          R Offline
                          rolz82
                          @Louis-DT-WR looks amazing pal, well done great build 👍
                          • R rolz82
                            Louis-DT-WR
                            @rolz82 thanks! I have such little knowledge of this bike (electrics and engine)
                            So many little things I want to know.
                              Louis-DT-WR
                              All lights, switches and horn are on and functional
                              Seat brackets made up.
                              Waiting for my starter motor to arrive.
                              Then decide what way to go for exhaust.
                              • Stevie WonderS Offline
                                Stevie Wonder
                                Now this would get my attention at a local bike night, any plans to paint it or just keep the flat steel look?
                                  Louis-DT-WR
                                  @Stevie-Wonder thanks. The tank is painted. In chrome silver powder coat. I was going to go all black but I wanted it to shine a bit
                                    Louis-DT-WR
                                    Took so many attempts to get the starting circuit to work. Checked everything, earths, relays, switches, batteries, motor and cables.
                                    The first lithium battery I bought was total crap, couldn't crank the engine over even though cross reference numbers said it was correct. Bought a shido and works perfectly.
                                    Made a numbplate holder + front "number plate"
                                    The most exciting part is the exhaust! Cut off about 10kg of the baffles. Shortened the silencers right down and made up the end covers.
                                    Still got to wrap the exhaust
                                    markus.wM 1 Reply Last reply
                                      Looks properly smart that!
                                        Louis-DT-WR
                                        @Calum looking forward to hearing it 🙂
                                        N 1 Reply Last reply
                                          @Louis-DT-WR Looks mighty fine dude, is your bike named after your sweetheart???
