  3. Other
  4. CB750 scrambler project
  • Louis-DT-WRL
    Louis-DT-WRL
    Been driving me crazy how the seller of the engine said it was from a cb750 but appears to be a cbx750 engine (much older + hydraulic clutch) rc17/17E
    But the engine apparently had only done 12k
    Also looks very new for something that would be 40 years old nearly.
    After a lot of research the Japanese did a later 2007 LTD with the Rc17E engine when looking at the part numbers for the upper crankcase on this models parts diagram it confirms this.
    This is a super rare models engine, + hydraulic clutch optional extra. On an import!
    But it will work perfectly for me, just ordered the correct pulse generator.
    Writing this down for future reference because I'll forget.
    • Louis-DT-WRL
      Louis-DT-WRL
      Started on the looming and electrics.
      Repositioned the coils to clear the fuel tank.
      Little jobs like that take a lot of time getting right.
      My holster on the headlight number board is all part of the walking dead style bike. It definitely wouldn't be ridden with that on it 😂 even though I'm trained on glocks , this is just a replica.
      Only used for pics 🙂
      R 1 Reply Last reply
      • Louis-DT-WRL Louis-DT-WR
        R
        R
        rolz82
        @Louis-DT-WR this looks amazing, well done
        • R rolz82
          Louis-DT-WRL
          Louis-DT-WRL
          @rolz82 thank you, working through all the electrics. My least favourite thing
            Wow, this looks gnarly as fuck!
            • Louis-DT-WRL
              Louis-DT-WRL
              Working through the electrics. I've got my rear indicators and tail lights sorted.
              I made a CDI holder to relocate it.
              Fuse box and indicator regular relocated.
              Front lights, indicators and horn on.
              Ignition barrel relocation plate made.
              Just sorting a battery box and the battery is on order. I can't fully test what connector goes where until the battery comes.
              • Louis-DT-WRL
                Louis-DT-WRL
                Well I put the engine in alone which was a very heavy task 💪 killed my back haha. Lining it up with the mounts while the bike was leaning again the bench. (You can't fit the engine when the chassis is on a bike lift)
                Got my battery box mounted with the lithium battery. Its so light! I thought it was just a empty case!
                Carbs on + filters and cables. Fitting the carbs was tricky, the rubber manifolds are so hard. I'd replace them but £150+vat for 4 and they're not cracked.
                  Louis-DT-WRL
                  Louis-DT-WRL
                  I even have a engine lift but it would have needed an offset cradle made up to clear the frame
                    That does look smart as f to be fair!
                      Louis-DT-WRL
                      Louis-DT-WRL
                      @Calum cheers man. Its literally a case of getting parts in my hands and making it fit/fabricate parts. I wish fowler's would hurry up, waiting ages for my rear brake parts. And side stand bits
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        Little bits done, oil cooler fully connected, the pipes were bent, took a while to get them right.
                        Oil filter came finally.
                        PCV filters on.
                        Started seat mounts and ignition switch relocation.
                        The 2 most expensive items I need is an exhaust and starter motor.
                        Still undecided what tank colour. I'm thinking Matt gunmetal grey. I was going to go black but think that would be over kill.
                          PCV filters on.
                          @Louis-DT-WR match your tank to the cam covers maybe
                            PCV filters on.
                            @Louis-DT-WR You'll be too scared to get that beast dirty for-sure!!! 😂
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @declan satin silver would be nice but not too stealth.
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @NINJA always the case but haven't gone OCD on this. Its got scratches and scruffs on the engine and forks. And I like it looking ragged
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  Lights check on.
                                  Tail lights seem to have not power, maybe but headlight is on when ignition on. Brake lights not working 🤔 maybe it will when engine is running.?
                                  Horn was faulty,
                                  All 4 indicators would flash, so I had it wire in a diode and earth the dial indicator light
                                  Clutch hydraulic line arrived and installed.
                                  Tank painted, I have a decal coming for it.
                                  Ignition switch installed
                                    Lights check on.
                                    Horn was faulty,
                                    R
                                    R
                                    rolz82
                                    @Louis-DT-WR looks amazing pal, well done great build 👍
                                    • R rolz82
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @rolz82 thanks! I have such little knowledge of this bike (electrics and engine)
                                      So many little things I want to know.
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        All lights, switches and horn are on and functional
                                        Seat brackets made up.
                                        Waiting for my starter motor to arrive.
                                        Then decide what way to go for exhaust.
                                        • Stevie WonderS
                                          Stevie WonderS
                                          Stevie Wonder
                                          Now this would get my attention at a local bike night, any plans to paint it or just keep the flat steel look?
