  3. Other
  4. CB750 scrambler project
    @Louis-DT-WR my thirst for knowledge has got the better of me I've just done a bit of googling and apparently it's only four strokes have 2 cables because the extra vacuum created by a 4 stroke can cause the throttle slide to flutter and jam against the side of the body. That seems to me the most logical explanation so far.
    Louis-DT-WRL
    Louis-DT-WRL
    @markus-w possible. The other thing with this engine is why does it have 2 oil fillers caps 🤷‍♂️ 1 says (don't open) but that's the sprocket side.
    In some pictures I see that's where the dipstick is on some bikes. My dipsticks on the clutch cover side like most bikes.
    Haynes don't do a cbx750 manual.
    Just going to persist working through all the small bits.
    • Louis-DT-WRL Louis-DT-WR
      Louis-DT-WRL
      Louis-DT-WRL
      So the carbs were very similar but not correct.
      So I started again 😂 parts are taking so long to come from overseas
      All new float bowl gaskets, diaphragms, o-rings and rejetted.
      Powder coated parts
      Stainless steel Allen cap bolts
        Too many strokes in that engine
          Louis-DT-WRL
          Louis-DT-WRL
          @Darty yes but 4 cylinders is a nice compensation
          I've got a name for her.... "Lucille" 😂🏏
            I mean, yeah I agree two many strokes.
            But doesn't stop this being a really interesting and cool build.
            Loving it pal, keep it up!
              Louis-DT-WRL
              Louis-DT-WRL
              @Calum cheers man, will keep posting when I get some big progress, stupid Chinese virus is holding up my parts
              • Louis-DT-WRL
                Louis-DT-WRL
                Finally my bar clamps came, 3 weeks.
                I've got the controls, grip, master cylinders on. Front brake operational.
                Choke and throttle cables.
                Front headlight on the number board (not finished yet) more to add to it.
                Pro taper contour bars.
                Rear fender (when pulled out, it's a shovel! (Entrenching tool))
                Slowly making progress.
                  @Louis-DT-WR i like the shovel rear fender adds character
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    Been driving me crazy how the seller of the engine said it was from a cb750 but appears to be a cbx750 engine (much older + hydraulic clutch) rc17/17E
                    But the engine apparently had only done 12k
                    Also looks very new for something that would be 40 years old nearly.
                    After a lot of research the Japanese did a later 2007 LTD with the Rc17E engine when looking at the part numbers for the upper crankcase on this models parts diagram it confirms this.
                    This is a super rare models engine, + hydraulic clutch optional extra. On an import!
                    But it will work perfectly for me, just ordered the correct pulse generator.
                    Writing this down for future reference because I'll forget.
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      Started on the looming and electrics.
                      Repositioned the coils to clear the fuel tank.
                      Little jobs like that take a lot of time getting right.
                      My holster on the headlight number board is all part of the walking dead style bike. It definitely wouldn't be ridden with that on it 😂 even though I'm trained on glocks , this is just a replica.
                      Only used for pics 🙂
                      R 1 Reply Last reply
                        R
                        R
                        rolz82
                        @Louis-DT-WR this looks amazing, well done
                        • R rolz82
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @rolz82 thank you, working through all the electrics. My least favourite thing
                            Wow, this looks gnarly as fuck!
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              Working through the electrics. I've got my rear indicators and tail lights sorted.
                              I made a CDI holder to relocate it.
                              Fuse box and indicator regular relocated.
                              Front lights, indicators and horn on.
                              Ignition barrel relocation plate made.
                              Just sorting a battery box and the battery is on order. I can't fully test what connector goes where until the battery comes.
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                Well I put the engine in alone which was a very heavy task 💪 killed my back haha. Lining it up with the mounts while the bike was leaning again the bench. (You can't fit the engine when the chassis is on a bike lift)
                                Got my battery box mounted with the lithium battery. Its so light! I thought it was just a empty case!
                                Carbs on + filters and cables. Fitting the carbs was tricky, the rubber manifolds are so hard. I'd replace them but £150+vat for 4 and they're not cracked.
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  I even have a engine lift but it would have needed an offset cradle made up to clear the frame
                                    That does look smart as f to be fair!
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      @Calum cheers man. Its literally a case of getting parts in my hands and making it fit/fabricate parts. I wish fowler's would hurry up, waiting ages for my rear brake parts. And side stand bits
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        Little bits done, oil cooler fully connected, the pipes were bent, took a while to get them right.
                                        Oil filter came finally.
                                        PCV filters on.
                                        Started seat mounts and ignition switch relocation.
                                        The 2 most expensive items I need is an exhaust and starter motor.
                                        Still undecided what tank colour. I'm thinking Matt gunmetal grey. I was going to go black but think that would be over kill.
                                          PCV filters on.
                                          @Louis-DT-WR match your tank to the cam covers maybe
