  3. TDR
  4. TDR125 4GW
TDR125 4GW
78 Posts 8 Posters 45.8k Views 2 Watching
  • MightymanM Offline
    MightymanM Offline
    #21
    I always thought replacing my TDR clocks with something like this would look a bit out of place as the stock one moulds nicely into the plastics. Bet theres a big hole there now! 😂
    tdr125gregT 1 Reply Last reply
    • MightymanM Mightyman
      tdr125gregT Offline
      tdr125gregT Offline
      tdr125greg
      @Mightyman I have thought about the same problem but how about 3d printing a new speedo surround then fibre glassing bondo, filler paint to finish ?
      TDR125 🔥
      Put some respek on it! 😂
      MightymanM 1 Reply Last reply
      • tdr125gregT tdr125greg
        MightymanM Offline
        MightymanM Offline
        @tdr125greg That is a very nice idea actually! Would be even better if you could save the fussing with fibre glass and just get a snug fit with something 3D printed.
        • F Offline
          F Offline
          wrote on last edited by finnerz89
          #24
          Running a vapour on my DT. Homemade mounting bracket
          • F Offline
            F Offline
            https://imgur.com/zi9671n
            • F finnerz89
              tdr125gregT Offline
              tdr125gregT Offline
              tdr125greg
              @finnerz89 looks tidy mate, how responsive is the Rev meter and do you have the radiator temp sensor or the sensor that goes on the spark plug?
              TDR125 🔥
              • F Offline
                F Offline
                Temp sensor that fits inside the radiator fin. I might get one for the plug and wire them through a switch
                  Another purchase sees the trail tech vapor and indicator dash added to PROJECT TDR.
                  I purchased the kit on eBay from Moore speed racing for £150 all in which I thought was a good deal. 🔥🔥
                  Any of you guys run the vapor on a tdr/Dt before?
                  0_1488293323206_DSC_0017_1.JPG 😀
                  @tdr125greg vapor on my dt and I love it. Makes me feel like I got a spaceship at night with the shift lights flashing in my goggles. Haven't ridden the bike for years but back when I was a kid 🙂
                    tdr125gregT Offline
                    tdr125gregT Offline
                    tdr125greg
                    @Calum I'm really looking forward to seeing those shift lights in action
                    TDR125 🔥
                      MightymanM Offline
                      MightymanM Offline
                      @tdr125greg The one I fitted to my MT-03 was SUPER inaccurate with the rev counter... I fitted it to the spark plug wire as the instructions mentioned but at 60mph+ speed the revometer would be all over the place, claiming I needed to shift all the time 😂
                      • F Offline
                        F Offline
                        No problems with rev counter on mine, it's wired directly to the coil
                        • F finnerz89
                          @finnerz89 Never had any problems with the counter myself.
                          On my new build it csn be wired directly to the cdi
                          F 1 Reply Last reply
                            F Offline
                            F Offline
                            @Calum is that with the zeeltronic?
                            • F finnerz89
                              @finnerz89 Yeah I believe it's the green/yellow wire that will pulse when the ignition fires. So no need to wrap the HT lead you can just wire it directly to the CDI.
                              I would double check the wiring diagram first mind you.
                                tdr125gregT Offline
                                tdr125gregT Offline
                                tdr125greg
                                @Calum I've been in talks with borut at zeeltronic, and I have decided I will definitely order the cdi and the programmer within the next 2 months. I've seen many varied experiences using the Rev counter but I'm assuming that's down to a bad install as I've also seen the Rev counter work great..
                                TDR125 🔥
                                  MightymanM Offline
                                  MightymanM Offline
                                  @tdr125greg Yeah don't take my experience as fact, I expected that it wasn't the norm.
                                  CalumC tdr125gregT 2 Replies Last reply
                                    @Mightyman Way back when, When I took my bike license before the law changed, I did it on my DT.
                                    There is a bit where you must do national speed limit. Guess what? Vapor packed up. Looked down and I was doing 110 MPH I was like WTF! Bike only does 70 lol.
                                    I have had glitches sure, but the norm is that it is spot on.
                                      tdr125gregT Offline
                                      tdr125gregT Offline
                                      tdr125greg
                                      wrote on last edited by tdr125greg
                                      #38
                                      @Mightyman haha sorry man didn't mean to make it sound like I was roasting you lol..
                                      These things happen don't they and I'm sure the way you done it is a method stated in the trail tech manual.
                                      I guess Calum's way just picks the pulse up in a more accurate Manor 😀
                                      TDR125 🔥
                                        MightymanM Offline
                                        No worries @tdr125greg 😎 Would have preffered connecting it up directly but when I specified the bike was an MT-03 they just sent me the kit that was to be fitted around the spark plug wire and told me to do it that way. @Calum that's mad, would have put me right off... I managed to just about do my full test on a YBR 125. It was a bit of a struggle to get it up to speed round the corners in the mod 1 though.
                                        • F Offline
                                          F Offline
                                          It's the same cable whether you wrap it around the HT lead or wire it up to your coil. I went with coil as it seemed more reliable and accurate. Had the bike stripped at the time so it was no hassle to do.
