  4. Any ideas how i can run my ypvs without a battery
10 Posts 7 Posters 4.5k Views 1 Watching
  • rogeringR
    rogeringR
    rogering
    hi all my ypvs is a 3 wire setup and I have rewired the loom myself but unsure where I should place brown wire, red with I think would surge the servo so shall I connect it to alt live yellow/red or still a no-no I don't want a battery as I use it for purely off-road use last thought I've came across is a capacitor I'm not 100% so I could do with some useful info
    Cheers Dan
    A 1 Reply Last reply
    • MightymanM
      MightymanM
      If you are only using it off-road, why not just pin the YPVS open and remove the electrics from it completely?
      • rogeringR
        rogeringR
        rogering
        Hmm good thought I'm going to have to do that till I find a solution as I really want it running but not with a lumpy batt in the frame cheers mate
        DartyD 1 Reply Last reply
        • rogeringR rogering
          DartyD
          DartyD
          @rogering Using a Capacitor is just fine.
          I ran one for over 2years. If you are woods riding/ trail stuff then I highly recommend keeping the Servo Motor on it.
          YPVS gives the mid range torque you need out of it
          • G
            G
            gareth_iowc
            Mine used to work with a completely dead battery that didn't change. When the stator is making electric it works fine.
            DT125R 2000
            DRZ400 2006
            Golf Mk3 20v Turbo 1996
              Mine would be intermittent with a dead battery. The Aprilia RAVE doesn't work on a dead battery either. Different bike but just saying.
              • rogeringR
                rogeringR
                rogering
                To the boys talking about battery's please stop I don't want to hear it lol, I'm not on a stock loom I have rewired my own basic ignition loom without the need for a battery but I still have the regulator in circuit for a future headlight and assumed the pv servo would work off the regulator I'm assuming my only way is a capacitor any ideas what cap I need apart from a 12 v any specifics please
                  Cheers Dan
                  A
                  A
                  andrewj1680
                  @rogering according to the wire diagram on the 3 wire servo there should be black and yellow to cdi unit so this would be a live, a black should be earth put a fuse and then looks like brown is a remote earth
                  • D
                    dan28
                    it connects to wires coming from the cdi
                    black/yel wire with female bullet
                    black wire
                    brown wire
                    these live in what looks like a double female spade plug
                    • A andrewj1680
                      dan28
                      @andrewj1680 said in Any ideas how i can run my ypvs without a battery:
                      brown will be live
                      on yam wiring black is earth brown live
