  4. My dt125r/wr200 project
76 Posts 13 Posters 27.3k Views 1 Watching
  • A
    A
    andrewj1680
    0_1501174267559_20170727_174932.jpg 0_1501174301705_20170727_174823.jpg 0_1501174341294_20170727_174704.jpg 0_1501174374549_20170727_174646.jpg 0_1501174408339_20170727_174610.jpg 0_1501174445553_20170727_174540.jpg 0_1501174485655_20170727_174447.jpg 0_1501174521698_20170727_174322.jpg 0_1501174557446_20170727_174306.jpg 0_1501174605583_20170727_174248.jpg 0_1501174654591_1501174633995405717922.jpg
    Frame been acid dipped to kill any rust and then acid etc primed
    4
    • A andrewj1680
      @andrewj1680 ooooooooh must let me ride it when it's finished 😉
        Yes mate, proper job that!
        • DartyD
          DartyD
          NICE!
          I hope they washed the frame well after the Dip.
          Had such a headache with residual acid continuing to convert rust through and under welded sections.
          A 1 Reply Last reply
          • DartyD Darty
            NICE!
            A
            A
            andrewj1680
            @darty it was vapour blasted after so it should be ok fingers crossed, what would you suggest waiting awhile to see if anything comes through the primer before painting? I'm not in a rush altho i have pretty much everything to build it I'd just rather do it properly first time round
            • A andrewj1680
              @andrewj1680 I have no experience with this but you should wait no sense potentialy waisting time and materials
              • A
                A
                andrewj1680
                First rear swingarm fitup to check clearance before paint 😊
                • A
                  A
                  andrewj1680
                  • A
                    A
                    andrewj1680
                    Dt and wr carbs stripped vapour blasted inside and out and then internals ultrasonic cleaned 0_1501263584715_20170728_150955.jpg
                      Yes, that Swingingarm and shock are gorgeous?
                      They were fitted to the WR? Lush.
                        A
                        A
                        andrewj1680
                        @calum yes mate was hoping to get the forks in place too but i had both stems pressed out and the dt stem is actually bigger in diameter so currently having the hole bored to fit the stem
                        • A
                          A
                          andrewj1680
                          0_1502788415911_20170815_095948.jpg 0_1502788441138_20170815_094349.jpg 0_1502788468648_20170815_094339.jpg 0_1502788498857_20170815_094313.jpg 0_1502788527690_20170815_094308.jpg 0_1502788563039_20170815_094215.jpg 0_1502788592145_20170815_094226.jpg
                          Few more bits all stripped back to bare metal including a fuel tank already for primer
                            Looking forward to seeing this coming together.
                            • NottsbikerN
                              NottsbikerN
                              Cant beat a good kitchen build lol
                              Looks like you are doing a proper job mate 🙂
                              • G
                                G
                                gareth_iowc
                                does the stock dt wheel fit in that wr swing arm?
                                DT125R 2000
                                DRZ400 2006
                                Golf Mk3 20v Turbo 1996
                                • A
                                  A
                                  andrewj1680
                                  It does yes
                                  • NottsbikerN
                                    NottsbikerN
                                    Is the WR swingarm longer than the DTR one as it looks longer?
                                    Btw All Balls sell a complete overhaul kit for the WR via ebay for approx £60 which must be cheaper than Yamaha.
                                    • A
                                      A
                                      andrewj1680
                                      0_1505252701944_20170912_224212.png 0_1505252727608_20170912_224053.png 0_1505252753520_20170912_224022.png 0_1505252772650_20170912_223942.png 0_1505252797266_20170912_223917.png 0_1505252825314_20170912_223845.png 0_1505252846240_20170912_223823.png 0_1505252874637_20170912_223729.png 0_1505252912431_20170912_223633.png 0_1505252945965_20170912_223603.png 0_1505252985862_20170912_223536.png
                                      Mick Abbey tuned wr200 cylinder and head ready for the transplant
                                      • NottsbikerN
                                        NottsbikerN
                                        Looking good so far
                                        How much did the work cost for the tuning?
                                        • A
                                          A
                                          andrewj1680
                                          He charges £170 including postage back to you but he does do a good job it totally changed my dt125r it was like a different bike
