  4. My dt125r/wr200 project
76 Posts 13 Posters 27.3k Views 1 Watching
  • A andrewj1680
    He charges Β£170 including postage back to you but he does do a good job it totally changed my dt125r it was like a different bike
    @andrewj1680 I can't say I really notice much of a difference on my bike. I seriously must not have it set up properly
    A 1 Reply Last reply
      A
      A
      andrewj1680
      @calum my bike was seriously gutless I thought maybe it had been treated like a baby all it's life and having only done just over 4000miles it wanted a good thrashing to liven it up but it never did seem to break free, once I had the cylinder and head done it pulled hard for a 125 anyway lol
      • A andrewj1680
        @andrewj1680 Right, makes sense.
        My bike already had zeeltronic and I thought it pulled fairly hard regardless.
          A
          A
          andrewj1680
          @calum maybe that's why you didn't feel much from it as I know with zeeltronic you can programme the way the powervalve comes in so it comes in stronger where as I think Yamaha bring it in gradually, I might not feel much difference from the 200 being done as my 125 didnt have the servo fitted so when the powervalve does come on it comes on strong anyway where as I'm running the 200 on the wr loom and management along with the 5 wire servo
          • NottsbikerN
            NottsbikerN
            How radical is the porting compared to standard? I'm guessing you can specify what type of tune you want, or is it like the old Stan Stevens stage 1, 2, 3 system?
            • A
              A
              andrewj1680
              I'm normally asked what I want from the bike so I'm guessing he will time it to meet your needs, I don't hang around and don't like to sit in traffic so I just tell him to go all out with it
              • NottsbikerN
                NottsbikerN
                Will be interested to hear how it rides on the road when built up.
                Can't beat a healthy two stroke on the road πŸ™‚
                • A
                  A
                  andrewj1680
                  My dtr pulls hard all the way to red line with the cylinder and head he did for that, it used to drop off top end however it doesn't anymore, imo it's worth the money
                  • NottsbikerN Nottsbiker
                    @nottsbiker Yeah it's not really stage this stage that.
                    It's more, I run the bike 10K plus and thus the porting should accomodate this, I.E. very late port timings causing lots of lost air and fuel below peak power, or I want punchy mid range, which would tell him how it should be ported.
                    • NottsbikerN
                      NottsbikerN
                      I think I'd go for mid range as most of my riding is around the city centre and quick get aways with an easy wheelie or two is ideal for me πŸ™‚
                        A
                        A
                        andrewj1680
                        @nottsbiker mine is ported for top end but will still come up on the back wheel in 3rd
                        • NottsbikerN
                          NottsbikerN
                          Glad to hear πŸ˜‰
                          • A
                            A
                            andrewj1680
                            Well that's the pic update out the question lol loads of nice fresh red bits frame, rear shock spring, radiator mounts,headlight bracket, rear peg mounts and rear grab handle all done Rosso red
                            ricky0115R 1 Reply Last reply
                            • A andrewj1680
                              ricky0115R
                              ricky0115R
                              ricky0115
                              @andrewj1680 did you have to remove the spring for painting?
                              • ricky0115R ricky0115
                                @ricky0115 Yeah but it's not a hard job to do
                                  ricky0115R
                                  ricky0115R
                                  ricky0115
                                  @calum I am a total novice to motorcycles, normally I don’t venture past building my brothers pushbike at Xmas πŸ˜‚
                                    @ricky0115 You basically compress the spring. which allows you to remove the retaining washer. It then just slides off.
                                      ricky0115R
                                      ricky0115R
                                      ricky0115
                                      @calum oh I think I will leave it, a friend of mine did that and ended up with a broken chin and dentures. Saying that it was a car shock so much more powerful I guess you could probably compress the DT spring with your hands
                                      F 1 Reply Last reply
                                        F
                                        F
                                        @ricky0115 not likely, still requires a lot of force
                                        • A
                                          A
                                          andrewj1680
                                          I compressed it by hand so there isn't a lot of tension on the really and I'm running the dt200wr rear shock setup so it's possibly easier to do giving that you can turn the stiffness to suit
