  3. Exhaust
  4. Anyone mounted fmf on Dtx?
23 Posts 7 Posters 9.6k Views 1 Watching
    @calum can you use some sort of bendable tubing?
    @irongamer727 No?
    Read up about Two Stroke Exhausts. They are finely tuned to an engine. You won't want to alter the pipe's shape in anyway. In fact, you want a pipe designed for that engine.
    There is a lot of maths involved.
      @irongamer727 No?
      @calum so I have to bend the fmf silencer into the form my existing silencer has?
        @irongamer727 I take it your not using a direct replacement FMF pipe? (That is if they actually make one for the DTX?) If not then I would imagine that you would struggle to bend it to fit.
          Tah Dah! WR200 FMF Powercore2/ DEP expansion chamber.
          Not easy to mount, but sounds fantastic.
            @irongamer727 I’m sure if you take both the fmf and your current system to either a metal works welding shop or a custom exhaust shop who make exhaust from scratch they will work something out but is it really worth it after all that? You could just get a shorty dep with an fmf sticker
            • A
              A
              andrewj1680
              @declan said in Anyone mounted fmf on Dtx?:
              Wr200fmf is a direct bolt up all I did was mount it on the rear on the grab handle rather that the original exhaust mount
              • A andrewj1680
                scrimsmustang
                wrote on last edited by scrimsmustang
                @andrewj1680 Front pipe just bolts on, like DT200R standard onto 125 different part numbers same exhaust no restrictions.
                A 1 Reply Last reply
                • S scrimsmustang
                  A
                  A
                  andrewj1680
                  @scrimsmustang my fmf came with a adapter plate that bolts straight to the head and then the front pipe slots over the top and then 2 springs to hols it together the same as you do on the crossers
                  declanD S 2 Replies Last reply
                  • A andrewj1680
                    @andrewj1680 mine has the same thing but I got a big one
                      Stop bragging dude!!! 😜
                      • A andrewj1680
                        scrimsmustang
                        @andrewj1680 said in Anyone mounted fmf on Dtx?:
                        Yeah they do So Cal dude !
                          @ninja hahaha
                          • Irongamer727I
                            https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F331387246138
                            Should fit with some mod right?
                            Tired of listening to my Arrow pipe which sound exactly like the stock pipe...
                            • Irongamer727I
                              Or
                              https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F263273308129
                              • Irongamer727I
                                My only concern is that the pipe itself is to short..
                                  I like that pro circuit one.
                                  Anything is possible mate, I am running a Jolly Moto end can on my dtr from An Aprilia RS so it's all doable.
                                  Irongamer727I 2 Replies Last reply
                                    @calum I mean the problem would be if the silencer is physically too short. That would be a real hassle
                                      @calum the really nice tapping noises from the dep pipes and almost every other depends on the thickness of the pipe right? And the silencer?
                                        @irongamer727 To be honest, I would be lying if I said I knew anything about exhausts.
                                        With your input, this post could be even better šŸ’—
