  3. Exhaust
  4. Anyone mounted fmf on Dtx?
23 Posts 7 Posters 9.6k Views 1 Watching
    @calum so I have to bend the fmf silencer into the form my existing silencer has?
    @irongamer727 I take it your not using a direct replacement FMF pipe? (That is if they actually make one for the DTX?) If not then I would imagine that you would struggle to bend it to fit.
      Tah Dah! WR200 FMF Powercore2/ DEP expansion chamber.
      Not easy to mount, but sounds fantastic.
        @irongamer727 I’m sure if you take both the fmf and your current system to either a metal works welding shop or a custom exhaust shop who make exhaust from scratch they will work something out but is it really worth it after all that? You could just get a shorty dep with an fmf sticker
        • A
          A
          andrewj1680
          @declan said in Anyone mounted fmf on Dtx?:
          Wr200fmf is a direct bolt up all I did was mount it on the rear on the grab handle rather that the original exhaust mount
          • A andrewj1680
            scrimsmustang
            wrote on last edited by scrimsmustang
            @andrewj1680 Front pipe just bolts on, like DT200R standard onto 125 different part numbers same exhaust no restrictions.
            A 1 Reply Last reply
            • S scrimsmustang
              A
              A
              andrewj1680
              @scrimsmustang my fmf came with a adapter plate that bolts straight to the head and then the front pipe slots over the top and then 2 springs to hols it together the same as you do on the crossers
              declanD S 2 Replies Last reply
              • A andrewj1680
                @andrewj1680 mine has the same thing but I got a big one
                  Stop bragging dude!!! 😜
                  • A andrewj1680
                    scrimsmustang
                    @andrewj1680 said in Anyone mounted fmf on Dtx?:
                    Yeah they do So Cal dude !
                      @ninja hahaha
                      • Irongamer727I
                        https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F331387246138
                        Should fit with some mod right?
                        Tired of listening to my Arrow pipe which sound exactly like the stock pipe...
                        • Irongamer727I
                          Or
                          https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F263273308129
                          • Irongamer727I
                            My only concern is that the pipe itself is to short..
                              I like that pro circuit one.
                              Anything is possible mate, I am running a Jolly Moto end can on my dtr from An Aprilia RS so it's all doable.
                              Irongamer727I 2 Replies Last reply
                                @calum I mean the problem would be if the silencer is physically too short. That would be a real hassle
                                  @calum the really nice tapping noises from the dep pipes and almost every other depends on the thickness of the pipe right? And the silencer?
                                    @irongamer727 To be honest, I would be lying if I said I knew anything about exhausts.
                                    With your input, this post could be even better šŸ’—
