  3. Exhaust
  4. Anyone mounted fmf on Dtx?
23 Posts 7 Posters 9.6k Views 1 Watching
    Anyone having any ideas how to do it?
    @irongamer727 I think @Calum, @Darty and @scrimsmustang have???
      Why did I want to say @andrewj1680
      Let's play the @ game lmao.
      I think he used a wr200 engine though and cut and rewelded brackets.
      Anything will fit given enough engineering.
        @calum can you use some sort of bendable tubing?
          @irongamer727 No?
          Read up about Two Stroke Exhausts. They are finely tuned to an engine. You won't want to alter the pipe's shape in anyway. In fact, you want a pipe designed for that engine.
          There is a lot of maths involved.
            @irongamer727 No?
            @calum so I have to bend the fmf silencer into the form my existing silencer has?
              @irongamer727 I take it your not using a direct replacement FMF pipe? (That is if they actually make one for the DTX?) If not then I would imagine that you would struggle to bend it to fit.
                Tah Dah! WR200 FMF Powercore2/ DEP expansion chamber.
                Not easy to mount, but sounds fantastic.
                  @irongamer727 I’m sure if you take both the fmf and your current system to either a metal works welding shop or a custom exhaust shop who make exhaust from scratch they will work something out but is it really worth it after all that? You could just get a shorty dep with an fmf sticker
                  • A
                    A
                    andrewj1680
                    @declan said in Anyone mounted fmf on Dtx?:
                    Wr200fmf is a direct bolt up all I did was mount it on the rear on the grab handle rather that the original exhaust mount
                    • A andrewj1680
                      scrimsmustang
                      wrote on last edited by scrimsmustang
                      @andrewj1680 Front pipe just bolts on, like DT200R standard onto 125 different part numbers same exhaust no restrictions.
                      A 1 Reply Last reply
                      • S scrimsmustang
                        A
                        A
                        andrewj1680
                        @scrimsmustang my fmf came with a adapter plate that bolts straight to the head and then the front pipe slots over the top and then 2 springs to hols it together the same as you do on the crossers
                        declanD S 2 Replies Last reply
                        • A andrewj1680
                          @andrewj1680 mine has the same thing but I got a big one
                            Stop bragging dude!!! 😜
                            • A andrewj1680
                              scrimsmustang
                              @andrewj1680 said in Anyone mounted fmf on Dtx?:
                              Yeah they do So Cal dude !
                                @ninja hahaha
                                • Irongamer727I
                                  https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F331387246138
                                  Should fit with some mod right?
                                  Tired of listening to my Arrow pipe which sound exactly like the stock pipe...
                                  • Irongamer727I
                                    Or
                                    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F263273308129
                                    • Irongamer727I
                                      My only concern is that the pipe itself is to short..
                                        I like that pro circuit one.
                                        Anything is possible mate, I am running a Jolly Moto end can on my dtr from An Aprilia RS so it's all doable.
                                        Irongamer727I 2 Replies Last reply
                                          @calum I mean the problem would be if the silencer is physically too short. That would be a real hassle
                                          With your input, this post could be even better šŸ’—
