  3. Exhaust
  4. Anyone mounted fmf on Dtx?
23 Posts 7 Posters 9.6k Views 1 Watching
  • Irongamer727I
    Anyone having any ideas how to do it?
      @irongamer727 I think @Calum, @Darty and @scrimsmustang have???
        Why did I want to say @andrewj1680
        Let's play the @ game lmao.
        I think he used a wr200 engine though and cut and rewelded brackets.
        Anything will fit given enough engineering.
          @calum can you use some sort of bendable tubing?
            @irongamer727 No?
            Read up about Two Stroke Exhausts. They are finely tuned to an engine. You won't want to alter the pipe's shape in anyway. In fact, you want a pipe designed for that engine.
            There is a lot of maths involved.
              @irongamer727 No?
              @calum so I have to bend the fmf silencer into the form my existing silencer has?
                @irongamer727 I take it your not using a direct replacement FMF pipe? (That is if they actually make one for the DTX?) If not then I would imagine that you would struggle to bend it to fit.
                  Tah Dah! WR200 FMF Powercore2/ DEP expansion chamber.
                  Not easy to mount, but sounds fantastic.
                    @irongamer727 I’m sure if you take both the fmf and your current system to either a metal works welding shop or a custom exhaust shop who make exhaust from scratch they will work something out but is it really worth it after all that? You could just get a shorty dep with an fmf sticker
                    • A
                      A
                      andrewj1680
                      @declan said in Anyone mounted fmf on Dtx?:
                      Wr200fmf is a direct bolt up all I did was mount it on the rear on the grab handle rather that the original exhaust mount
                      • A andrewj1680
                        scrimsmustang
                        wrote on last edited by scrimsmustang
                        @andrewj1680 Front pipe just bolts on, like DT200R standard onto 125 different part numbers same exhaust no restrictions.
                        A 1 Reply Last reply
                        • S scrimsmustang
                          A
                          A
                          andrewj1680
                          @scrimsmustang my fmf came with a adapter plate that bolts straight to the head and then the front pipe slots over the top and then 2 springs to hols it together the same as you do on the crossers
                          declanD S 2 Replies Last reply
                          • A andrewj1680
                            @andrewj1680 mine has the same thing but I got a big one
                              Stop bragging dude!!! 😜
                              • A andrewj1680
                                scrimsmustang
                                @andrewj1680 said in Anyone mounted fmf on Dtx?:
                                Yeah they do So Cal dude !
                                  @ninja hahaha
                                  • Irongamer727I
                                    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F331387246138
                                    Should fit with some mod right?
                                    Tired of listening to my Arrow pipe which sound exactly like the stock pipe...
                                    • Irongamer727I
                                      Or
                                      https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F263273308129
                                      • Irongamer727I
                                        My only concern is that the pipe itself is to short..
                                          I like that pro circuit one.
                                          Anything is possible mate, I am running a Jolly Moto end can on my dtr from An Aprilia RS so it's all doable.
                                          Irongamer727I 2 Replies Last reply
                                          With your input, this post could be even better šŸ’—
