  4. Kick stand kill switch
53 Posts 9 Posters 13.5k Views
  • F
    Doesn't the sidestand switch earth through the frame? Pretty sure mine only has 1 wire going to it, connect that to the frame somewhere and that should sort it
    SpannersS CalumC 3 Replies Last reply
      SpannersS
      SpannersS
      Spanners
      @finnerz89
      Thank you for the advice, l will have a go later! πŸ˜ƒπŸ‘
        @finnerz89 This was my thoughts exactly, but wasn't sure enough to post it.
          SpannersS
          SpannersS
          Spanners
          @finnerz89
          So I’ve just been on YouTube and l think now l should take the two wires and connect them then ground them both to the frame.
          I believe this is to stop the rectifier over heating.
          Does this sound about right? πŸ˜‚πŸ‘
          F 1 Reply Last reply
          • SpannersS Spanners
            @finnerz89
            @spanners that's a new one on me lol. You should only need to ground one of them
              I'd just get the side stand switch fitted.
              Is there any reason why you don't want one.
              My Aprilia didn't have one, it had a suicide stand. And on one occasion it didn't retract. I remember riding it for a few miles with the stand semi-down. And when I came round a bend, it chipped the floor nearly writing me off.
              It's a good lesson, I would always have one fitted given the choice.
              SpannersS 1 Reply Last reply
                SpannersS
                SpannersS
                Spanners
                @calum
                Well to buy a new one is around Β£60, considering to bike never had one and they seemed quite annoying if they fail l figured l would just over ride it.
                But I’ve had a word with the lads at GB Breakers and they have one for a decent price.
                Also l can’t figure out how to do it! Ha-ha!
                Will l ever get to ride the DT l have built......🀣
                  @calum
                  @spanners Hhm, never had one fail on me personally.
                  • D
                    dan28
                    I thought you cut the plug off then joined both wires together
                    • D dan28
                      SpannersS
                      SpannersS
                      Spanners
                      @dan28 l have tried that Dan, it doesn’t work.
                      Strangely it works a little bit, but as you go up the revs in cuts out.
                      It plays with you a little bit, then leaves you to do the walk of shame back to your house whilst it laughs behind your back.
                      Maybe I’ve dramatised that a little.....ha-ha! πŸ˜‚πŸ˜‘
                        dan28
                        @spanners
                        Did u cut the plug off an join the wires
                        Or are the plugs still there an u have joined the wire were it comes out the plug
                        • D dan28
                          @spanners
                          SpannersS
                          SpannersS
                          Spanners
                          @dan28 If you see the picture on the first post, all l have is the female end of where the kill switch plugs in.
                          I have never had a kill switch on the bike so l have nothing to figure it out from.
                          As said l jumped the two pins inside the connector, in theory completing the circuit.
                          Unfortunately this hasn’t solved the problem.
                          As said, any advice is greatly received! πŸ‘
                          • F
                            @Spanners what year is your bike? I've got the wiring diagrams sat here in front of me
                              SpannersS
                              SpannersS
                              Spanners
                              @finnerz89 Sorry for late reply. The bike is a X reg, 1999-2000.
                              • D
                                dan28
                                I m no expert but I reckon the plug is the problem chop it of an join both wires
                                The connectors inside the plug could be corroded as you said it does work but cuts out at higher revs
                                • Irongamer727I
                                  I noticed yesterday when I was going to start her up after a long ride (I literally shut her off and put the sidestand down and was going to start her up again immediately).
                                  But no, it wouldn't fire. So I thought of bumpstarting, and it fired immediately.
                                  Didn't really think much about it for the rest of the day, but this morning it wouldn't start with the stand down. It cuts the ignition when the stand is down, in neutral or not.
                                  Is there any point disassembling it? Or should I ordered a new?
                                  • Irongamer727I
                                      @irongamer727 Sounds more like the neutral switch is faulty.
                                      Does it start if you pull the clutch in?
                                        @calum I'll try
                                        • Irongamer727I
                                          #29
                                          It starts with the stand down and the clutch in.
                                          But cuts out as soon as I release the clutch(in neutral)
