  4. Kick stand kill switch
53 Posts 9 Posters 12.6k Views
  • SpannersS Spanners
    @calum
    I have done that Calum but it doesn’t seem to stop it killing the engine.
    And as said it is fine out of gear, just when you start to ride.
    I’m at a brick wall with it, l have had the Haynes manual out, sorted all if the wires.
    Installed indicators, even sorted the parking light out! Ha-ha!
    But this has beat me!
    Everything l watch on YouTube they have the kill switch and cut the switch off then use wire past the connectors.
    Where as I’m just jumping them at the female end connector?
    Unfortunately l know nothing about electrical, apart from common sense! 😃
    @spanners mines cut off where the wires come out of the actual switch
    SpannersS 1 Reply Last reply
      @calum
      N Offline
      N Offline
      @spanners Check the connectors for any corrosion, then check all wires too and from those connectors for corrosion or bare wire. As that will cause the circuit to short out and activate the kill switch.
        SpannersS Offline
        SpannersS Offline
        Spanners
        @declan
        Hi Declan
        Thanks for the advice, and yes that’s what a was saying.
        If you see in the picture, the Blue connector is what the kill switch plugs into.
        I don’t actually have a kill switch, so l can jump the wires past the female connector.
        Surely the CDI can’t be that intelligent where it requires a certain resistance? 😢
          I'd have to check the wiring diagram. But it's not doing anything clever.
          • N NINJA
            SpannersS Offline
            SpannersS Offline
            Spanners
            @ninja
            Thanks Ninja!
            I think that is the best step, checking all the associated wires for wear.
            Next thing is maybe buying a clucking kill switch! Ha-ha! 😂
            N 1 Reply Last reply
              @ninja
              Thanks Ninja!
              N Offline
              N Offline
              @spanners I'd check all the wires first dude, normally the kill switch is just an open or close switch, pretty much the same as a regular wall light switch. If the wiring is sound then you know it's a faulty switch and vice versa!!! 😉
              • F Offline
                F Offline
                Doesn't the sidestand switch earth through the frame? Pretty sure mine only has 1 wire going to it, connect that to the frame somewhere and that should sort it
                SpannersS CalumC 3 Replies Last reply
                  SpannersS Offline
                  SpannersS Offline
                  Spanners
                  @finnerz89
                  Thank you for the advice, l will have a go later! 😃👍
                    @finnerz89 This was my thoughts exactly, but wasn't sure enough to post it.
                      SpannersS Offline
                      SpannersS Offline
                      Spanners
                      @finnerz89
                      So I’ve just been on YouTube and l think now l should take the two wires and connect them then ground them both to the frame.
                      I believe this is to stop the rectifier over heating.
                      Does this sound about right? 😂👍
                      F 1 Reply Last reply
                        @finnerz89
                        F Offline
                        F Offline
                        @spanners that's a new one on me lol. You should only need to ground one of them
                          I'd just get the side stand switch fitted.
                          Is there any reason why you don't want one.
                          My Aprilia didn't have one, it had a suicide stand. And on one occasion it didn't retract. I remember riding it for a few miles with the stand semi-down. And when I came round a bend, it chipped the floor nearly writing me off.
                          It's a good lesson, I would always have one fitted given the choice.
                            SpannersS Offline
                            SpannersS Offline
                            Spanners
                            @calum
                            Well to buy a new one is around £60, considering to bike never had one and they seemed quite annoying if they fail l figured l would just over ride it.
                            But I’ve had a word with the lads at GB Breakers and they have one for a decent price.
                            Also l can’t figure out how to do it! Ha-ha!
                            Will l ever get to ride the DT l have built......🤣
                              @calum
                              @spanners Hhm, never had one fail on me personally.
                              • D Offline
                                D Offline
                                dan28
                                I thought you cut the plug off then joined both wires together
                                • D dan28
                                  SpannersS Offline
                                  SpannersS Offline
                                  Spanners
                                  @dan28 l have tried that Dan, it doesn’t work.
                                  Strangely it works a little bit, but as you go up the revs in cuts out.
                                  It plays with you a little bit, then leaves you to do the walk of shame back to your house whilst it laughs behind your back.
                                  Maybe I’ve dramatised that a little.....ha-ha! 😂😡
                                    D Offline
                                    D Offline
                                    dan28
                                    @spanners
                                    Did u cut the plug off an join the wires
                                    Or are the plugs still there an u have joined the wire were it comes out the plug
                                    • D dan28
                                      @spanners
                                      SpannersS Offline
                                      SpannersS Offline
                                      Spanners
                                      @dan28 If you see the picture on the first post, all l have is the female end of where the kill switch plugs in.
                                      I have never had a kill switch on the bike so l have nothing to figure it out from.
                                      As said l jumped the two pins inside the connector, in theory completing the circuit.
                                      Unfortunately this hasn’t solved the problem.
                                      As said, any advice is greatly received! 👍
                                      • F Offline
                                        F Offline
                                        @Spanners what year is your bike? I've got the wiring diagrams sat here in front of me
                                          SpannersS Offline
                                          SpannersS Offline
                                          Spanners
                                          @finnerz89 Sorry for late reply. The bike is a X reg, 1999-2000.
