  4. Kick stand kill switch
53 Posts 9 Posters 13.8k Views
    Pretty sure it's just an open circuit just gets closed merely by the kickstand switch.
    So short it out that should sort it out.
    SpannersS 1 Reply Last reply
      SpannersS
      SpannersS
      Spanners
      @calum
      I have done that Calum but it doesnโ€™t seem to stop it killing the engine.
      And as said it is fine out of gear, just when you start to ride.
      Iโ€™m at a brick wall with it, l have had the Haynes manual out, sorted all if the wires.
      Installed indicators, even sorted the parking light out! Ha-ha!
      But this has beat me!
      Everything l watch on YouTube they have the kill switch and cut the switch off then use wire past the connectors.
      Where as Iโ€™m just jumping them at the female end connector?
      Unfortunately l know nothing about electrical, apart from common sense! ๐Ÿ˜ƒ
      • SpannersS Spanners
        @calum
        @spanners mines cut off where the wires come out of the actual switch
          @calum
          @spanners Check the connectors for any corrosion, then check all wires too and from those connectors for corrosion or bare wire. As that will cause the circuit to short out and activate the kill switch.
            SpannersS
            SpannersS
            Spanners
            @declan
            Hi Declan
            Thanks for the advice, and yes thatโ€™s what a was saying.
            If you see in the picture, the Blue connector is what the kill switch plugs into.
            I donโ€™t actually have a kill switch, so l can jump the wires past the female connector.
            Surely the CDI canโ€™t be that intelligent where it requires a certain resistance? ๐Ÿ˜ข
              I'd have to check the wiring diagram. But it's not doing anything clever.
                SpannersS
                SpannersS
                Spanners
                @ninja
                Thanks Ninja!
                I think that is the best step, checking all the associated wires for wear.
                Next thing is maybe buying a clucking kill switch! Ha-ha! ๐Ÿ˜‚
                  @ninja
                  Thanks Ninja!
                  @spanners I'd check all the wires first dude, normally the kill switch is just an open or close switch, pretty much the same as a regular wall light switch. If the wiring is sound then you know it's a faulty switch and vice versa!!! ๐Ÿ˜‰
                  • F
                    Doesn't the sidestand switch earth through the frame? Pretty sure mine only has 1 wire going to it, connect that to the frame somewhere and that should sort it
                    SpannersS CalumC 3 Replies Last reply
                      SpannersS
                      SpannersS
                      Spanners
                      @finnerz89
                      Thank you for the advice, l will have a go later! ๐Ÿ˜ƒ๐Ÿ‘
                        @finnerz89 This was my thoughts exactly, but wasn't sure enough to post it.
                          SpannersS
                          SpannersS
                          Spanners
                          @finnerz89
                          So Iโ€™ve just been on YouTube and l think now l should take the two wires and connect them then ground them both to the frame.
                          I believe this is to stop the rectifier over heating.
                          Does this sound about right? ๐Ÿ˜‚๐Ÿ‘
                          F 1 Reply Last reply
                            @finnerz89
                            @spanners that's a new one on me lol. You should only need to ground one of them
                              I'd just get the side stand switch fitted.
                              Is there any reason why you don't want one.
                              My Aprilia didn't have one, it had a suicide stand. And on one occasion it didn't retract. I remember riding it for a few miles with the stand semi-down. And when I came round a bend, it chipped the floor nearly writing me off.
                              It's a good lesson, I would always have one fitted given the choice.
                                SpannersS
                                SpannersS
                                Spanners
                                @calum
                                Well to buy a new one is around ยฃ60, considering to bike never had one and they seemed quite annoying if they fail l figured l would just over ride it.
                                But Iโ€™ve had a word with the lads at GB Breakers and they have one for a decent price.
                                Also l canโ€™t figure out how to do it! Ha-ha!
                                Will l ever get to ride the DT l have built......๐Ÿคฃ
                                  @calum
                                  @spanners Hhm, never had one fail on me personally.
                                  • D
                                    dan28
                                    I thought you cut the plug off then joined both wires together
                                    • D dan28
                                      SpannersS
                                      SpannersS
                                      Spanners
                                      @dan28 l have tried that Dan, it doesnโ€™t work.
                                      Strangely it works a little bit, but as you go up the revs in cuts out.
                                      It plays with you a little bit, then leaves you to do the walk of shame back to your house whilst it laughs behind your back.
                                      Maybe Iโ€™ve dramatised that a little.....ha-ha! ๐Ÿ˜‚๐Ÿ˜ก
                                        dan28
                                        @spanners
                                        Did u cut the plug off an join the wires
                                        Or are the plugs still there an u have joined the wire were it comes out the plug
                                        • D dan28
                                          @spanners
                                          SpannersS
                                          SpannersS
                                          Spanners
                                          @dan28 If you see the picture on the first post, all l have is the female end of where the kill switch plugs in.
                                          I have never had a kill switch on the bike so l have nothing to figure it out from.
                                          As said l jumped the two pins inside the connector, in theory completing the circuit.
                                          Unfortunately this hasnโ€™t solved the problem.
                                          As said, any advice is greatly received! ๐Ÿ‘
