Kick stand kill switch
@ninja
Thanks Ninja!
I think that is the best step, checking all the associated wires for wear.
Next thing is maybe buying a clucking kill switch! Ha-ha!
Doesn't the sidestand switch earth through the frame? Pretty sure mine only has 1 wire going to it, connect that to the frame somewhere and that should sort it
@finnerz89
Thank you for the advice, l will have a go later!
@finnerz89 This was my thoughts exactly, but wasn't sure enough to post it.
@finnerz89
So Iβve just been on YouTube and l think now l should take the two wires and connect them then ground them both to the frame.
I believe this is to stop the rectifier over heating.
Does this sound about right?
@finnerz89
I'd just get the side stand switch fitted.
Is there any reason why you don't want one.
My Aprilia didn't have one, it had a suicide stand. And on one occasion it didn't retract. I remember riding it for a few miles with the stand semi-down. And when I came round a bend, it chipped the floor nearly writing me off.
It's a good lesson, I would always have one fitted given the choice.
@calum
Well to buy a new one is around Β£60, considering to bike never had one and they seemed quite annoying if they fail l figured l would just over ride it.
But Iβve had a word with the lads at GB Breakers and they have one for a decent price.
Also l canβt figure out how to do it! Ha-ha!
Will l ever get to ride the DT l have built......
@calum
@dan28 l have tried that Dan, it doesnβt work.
Strangely it works a little bit, but as you go up the revs in cuts out.
It plays with you a little bit, then leaves you to do the walk of shame back to your house whilst it laughs behind your back.
Maybe Iβve dramatised that a little.....ha-ha!
@spanners
Did u cut the plug off an join the wires
Or are the plugs still there an u have joined the wire were it comes out the plug@dan28 If you see the picture on the first post, all l have is the female end of where the kill switch plugs in.
I have never had a kill switch on the bike so l have nothing to figure it out from.
As said l jumped the two pins inside the connector, in theory completing the circuit.
Unfortunately this hasnβt solved the problem.
As said, any advice is greatly received!
@finnerz89 Sorry for late reply. The bike is a X reg, 1999-2000.
I noticed yesterday when I was going to start her up after a long ride (I literally shut her off and put the sidestand down and was going to start her up again immediately).
But no, it wouldn't fire. So I thought of bumpstarting, and it fired immediately.
Didn't really think much about it for the rest of the day, but this morning it wouldn't start with the stand down. It cuts the ignition when the stand is down, in neutral or not.
Is there any point disassembling it? Or should I ordered a new?
@irongamer727 Sounds more like the neutral switch is faulty.
Does it start if you pull the clutch in?
@calum I'll try
