  4. YPVS tips
YPVS tips
30 Posts 6 Posters 7.1k Views
  • Glynn123G Glynn123
    Didnt bother lubing my PV after rebuilding, ensured all surfaces were very clean and mirror polished, it doesnt do a full rotation and moves as much as say a rev counter or speedometer, the bushes would well outlast a piston un lubed, the thing you should really worry about it carbon sticking to the powervalve, so keep it clean and if you can be arsed mirror polish it.
    @glynn123 when cleaning the pv. Should you always buy new o rings or can they normally be reused? How many km until you should inspect and clean?
    CalumC ZrakoZ 2 Replies Last reply
      @irongamer727 Pretty sure it comes with the Athena gasket kit.
      I can't say I have ever gone out my way to replace the o ring or clean the valve.
        ZrakoZ
        ZrakoZ
        Zrako
        @irongamer727 when Im cleaned mine , I had new seal and old seal in hand and couldnt tell the difference.
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
        • ZrakoZ Zrako
          @zrako when I rebuilt my top end my o rings were no bullshit litteraly square although my piston was about 2 years of hard riding old
          • Irongamer727I
            The Haynes manual says you need to make sure the pv is mounted correctly and not 180° wrong. Is it possible to mount it wrong? I mean it only fits one way?
              @irongamer727 I guess it’s in the manual for a reason but I don’t actually know
                @irongamer727 It means ensuring it's not upside down....I'd imagine.
                  Yup, it seems you can fit it upside down, thus restricking the bike.
                  Im pretty sure some bikes where sold in a restricted version like this.
                  • Irongamer727I
                    Can you twist and turn the servo motor for the pv without risking causing damage to it? I need to do so since the current setting is not optimal.
                      @irongamer727 Your servo is fubar anyway right? So can't see what harm it would do.
                        Nope have a new one
                        • Irongamer727I
                          • Irongamer727I
                            my question is wheather or not you could "rotate" the servo manually in order to adjust the pv better. The 2nd pulley is obviously a bit too far out.
                              Yeah isn't that how you're meant to adjust them anyway. Just use a set of spanners to adjust the locking nuts, the tension ought to pull the servo the right way. Then lock off.
                              I might be having a mental block, but that's how you adjust them.
                                @calum think he might mean litteraly turning with your finger tips but the way you mentioned is the best way
                                  @declan I think turn it from the PV housing should suffice.
                                    @calum yep to turn it with with your fingers would be massively overkill really
                                      @declan naah, you guys underestimate the force required to turn that servo. Fingertips or pull HARD at the pulley
                                      • Irongamer727I
                                        Do you think my servo settings are okay? It works beautifully and opens right. However I am not happy with the way it is adjusted. The 2nd pulley screw is as you can see much further out than the 1st. Have a look at the servo! No pleased with that either. Woud have wanted it more centred. But frankly that was the only way it would work. Seems okey?
                                          @irongamer727 Just whip the exhaust off and have a look. It should be flush with the exhaust port. Doesn't matter where the screws are as they should be shielded with the rubber grommets.
