  4. Cutout acceptable?
Cutout acceptable?
14 Posts 6 Posters 1.9k Views
  • Irongamer727I Offline
    As you can see the entire top of the airbox has been cutout (not by me). The question is weather its safe enought from scrap, dirt and water? I dont mind cleaning it often. Or should I do something about it? It will be rejetted since I have installed a few bits and pieces during the winter.
      Perfectly fine. Sir boxes on these are really restrictive.
        @calum are you running the stock box?
          @irongamer727 No box mate, pod filter, easier to jet, less restrictive.
          • Glynn123G Offline
            Glynn123G Offline
            Glynn123
            wrote on last edited by Glynn123
            What's your opinions on cutting out the airbox lid Calum? I'm thinking of doing this myself, however maybe abit lean on stock carb with a full system and 250 main jet?
            • Glynn123G Glynn123
              @glynn123 So I think it's absolutely criminal, however Rob @ Yamaha Skellerns Cheltenham tells me that these bikes are massively restricted by the air box and he encourages the cutting of them for performance sake. As said, I just run a pod filter as it means you don't butcher an OEM part.
              Glynn123G 1 Reply Last reply
                Glynn123G Offline
                Glynn123G Offline
                Glynn123
                @calum mines already slightly butchered haha, I have my snorkel removed so was thinking of just elongating the hole across, not cutting the whole lid, however I might just leave it for this summer.
                  @glynn123 I'd just cut the whole lid off if it's already been cut.
                  • F Offline
                    F Offline
                    Seen on another forum that the snorkel off other DT's fit and they aren't as restrictive, I think I saw a guy with a DT175 one?
                    I guess the DT200 or 230 would fit as well
                    • FusedF Offline
                      FusedF Offline
                      Fused
                      You might want to keep the box/snorkel if you plan to go off road a lot, through fords etc, as cone filters and the like are not so great at keeping water out of your engine
                      • FusedF Fused
                        @fused True, but if the bike is purely used on the road then it will be fine, plus ssaves you buthering the box for more performance.
                          @Calum look further up
                            @Darty here you can see
                            • Louis-DT-WRL Offline
                              My wr200cc/dt125r hybrid engine runs with lid cut off. I ran it also with the 125 engine. You just need to jet accordingly.
