  4. Cutout acceptable?
Cutout acceptable?
14 Posts 6 Posters 1.9k Views
    Perfectly fine. Sir boxes on these are really restrictive.
      Irongamer727I Offline
      @calum are you running the stock box?
        @irongamer727 No box mate, pod filter, easier to jet, less restrictive.
        • Glynn123G Offline
          Glynn123G Offline
          Glynn123
          wrote on last edited by Glynn123
          What's your opinions on cutting out the airbox lid Calum? I'm thinking of doing this myself, however maybe abit lean on stock carb with a full system and 250 main jet?
          • Glynn123G Glynn123
            @glynn123 So I think it's absolutely criminal, however Rob @ Yamaha Skellerns Cheltenham tells me that these bikes are massively restricted by the air box and he encourages the cutting of them for performance sake. As said, I just run a pod filter as it means you don't butcher an OEM part.
            Glynn123G 1 Reply Last reply
              Glynn123G Offline
              Glynn123G Offline
              Glynn123
              @calum mines already slightly butchered haha, I have my snorkel removed so was thinking of just elongating the hole across, not cutting the whole lid, however I might just leave it for this summer.
                @glynn123 I'd just cut the whole lid off if it's already been cut.
                • F Offline
                  F Offline
                  Seen on another forum that the snorkel off other DT's fit and they aren't as restrictive, I think I saw a guy with a DT175 one?
                  I guess the DT200 or 230 would fit as well
                  • F Offline
                    F Offline
                    Fused
                    You might want to keep the box/snorkel if you plan to go off road a lot, through fords etc, as cone filters and the like are not so great at keeping water out of your engine
                    • F Fused
                      @fused True, but if the bike is purely used on the road then it will be fine, plus ssaves you buthering the box for more performance.
                      • Irongamer727I Offline
                        @Calum look further up
                          @Darty here you can see
                          • Louis-DT-WRL Offline
                            My wr200cc/dt125r hybrid engine runs with lid cut off. I ran it also with the 125 engine. You just need to jet accordingly.
