  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 63.4k Views
    What would you do?
    Take a full refund and buy a forged piston to the original Cylinder and mount that or take another Athena cylinder?
    The carb is already set up for the Athena but it's not much work to set it back to stock.
    Could the bike be worth more with the Athena?
    @irongamer727 I don't think so, if it were me in the market for a bike I'd rather buy stock or close to it and do the work myself.
    Other people might feel differently but that's my 2p
      Me, I would put back to stock and live with that, at least you know where you are with that. If you get another barrel could be more problems and no guarantee jetting would remain the same.
      But that's me.
      • Glynn123G
        Glynn123G
        Glynn123
        Would rather a standard bore than a 170 if I'm honest, get it ported and I'm doubting itd be far off the Athena. Or if you're feeling the bigger cc kits splash out for a BARacing 200kit and really feel the power 😍
        • Glynn123G Glynn123
          @glynn123 I'm so done with the big bore kits
            @irongamer727 I feel your pain bro
              Get the stock barrel ported and engine the 14k red line.
              • B
                B
                Bananper
                Does the 170 kit even give more power? I've heard so much bad about it 😂
                • B Bananper
                  @bananper Not peak, but more power through the midrange. I want to say torque, but I always get thumbed down for saying that.
                  B 1 Reply Last reply
                    B
                    B
                    Bananper
                    @calum so basically you lose some peak power in exchange for mid range power? Correct me if I'm wrong 🤓
                      @calum Ehmm 😬
                      • B Bananper
                        @bananper Without a Dyno Graph it's hard to tell. But due to the port timings being way out, once you start climbing through the revs, the opportunity for the power to be made starts diminishing.
                        Hence why at low RPM's you have the extra CC's to help deliver more low down grunt, but the power tapers off and the gap between a stock barrel and Athena barrel starts to thin out. You definitely lose overrev with the big bore, so the stock barrel will continue to rev out further, allow you to zap out a few extra ponies with the help of porting.
                        Two strokes in general don't love over square engines, the fact that the big bore kit widens the bore whilst maintaining the stroke exacerbates this. A longer stroke is ideal for this kit. There is the potential then, for the longer stroke to correct the port timings, out by 3mm I'm led to believe, to actually correct the issues with the barrel.
                        But by the time you've done all that, you may as well have just thrown a 3XP0 cylinder and crank and be done with it.
                        I haven't the expertise or experience to really comment on how any of this translates. But it's just what I've read from various sites.
                          B
                          B
                          Bananper
                          @calum 3XP0 is wr200 engine right?
                          • B Bananper
                            @bananper DT200R I think.
                              B
                              B
                              Bananper
                              @calum is there any difference between wr200 and the dt200?
                              • B Bananper
                                @bananper wr is a competition bike.
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  I believe the dt200r is a 3ET barrel. Dt200wr and wr200 share the same 3xp cylinder which is nickasil plated but you can buy steel sleeves for them. I believe the dt200wr is autolube and has a tachometer at generator different dor the electrics
                                  Also the dt230 cylinder and crank is a possibility 🤑 never seen this one done.
                                  • 2
                                    2stroketerry
                                    Best option is to get your standard 125 barrel re-sleeved to 66mm then fit a Wiseco Forged Yamaha BLASTER YFS 200 Piston Kit 66mm. Piston gudgeon pin and small end bearing same size as dt 125, you will also need your head machining to suit. Kpm or Pjme will re-sleeve the barrel to 66mm and machine the head to match and also works out including forged piston kit and work to barrel and head less than half the price of the Athena kit. Also having a steel liner gives you the option of several rebores. https://www.ebay.com/itm/Wiseco-Yamaha-BLASTER-YFS-200-Piston-Kit-Top-End-Bearing-66mm-Std-Bore-1988-06-/173027889008?fits=Make%3AYamaha
                                    declanD Louis-DT-WRL 2 Replies Last reply
                                    • 2 2stroketerry
                                      @2stroketerry very cool I love all the little Frankenstein things you can do to engines
                                      • 2
                                        2stroketerry
                                        Wossner do a forged piston kit for the dt 125 that is 61mm and the absolute maximum can bore a dt barrel to. Gives around 146cc. https://www.ebay.co.uk/itm/Wossner-Piston-Kit-KTM-LC2-1991-2006-Yamaha-DT125-Over-Bore-61mm/371410153446?hash=item5679c52fe6:g:YI8AAOSwHnFVyn8J
                                        • 2 2stroketerry
                                          @2stroketerry what gains should I expect from doing the overbore and porting
