  4. The wr200 3xp / dt125r 3bn hybrid 200cc engine no.2
43 Posts 10 Posters 14.6k Views 2 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Crankshaft is finally due to arrive tomorrow 😁
    After speaking of the anodizers they recommend not anodising on a sandblasted finish.
    So I Powder coated instead.
    F CalumC 2 Replies Last reply
    • Louis-DT-WRL Louis-DT-WR
      @Louis-James similar colour to my cases! 👍 Looking good dude
        Louis-DT-WRL
        Louis-DT-WRL
        @finnerz89 thanks, I chose at random tbh as the samples are so hard to tell from in my experience but happy with the outcome
          @Louis-James They've come up well.
          I was always really sceptical about powdercoating the crank cases.
            @Calum howcome
            • Louis-DT-WRL
              Louis-DT-WRL
              Finally arrived
              3
                Finally arrived
                @Louis-James Very cranky!!! :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣
                • MiniaM
                  MiniaM
                  Minia
                  Looking good! Then again everything you do looks outstanding to me.
                  • MiniaM Minia
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @Minia thanks man. I like to do my best 😉
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      New powervalver but not genuine from Greece.
                        @Louis-James If it's not genuine then what are the Yammy packets for??? :confused_face:
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @NINJA the powervalve is a reproduction. I have lots of brand new genuine parts that came from fowlers
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            What is this? I've not seen it before from memory clips inside the splined washer .
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              Cases bored out for the larger crankshaft
                                @Louis-James Sweet looking job dude. :clapping_hands:
                                  WOw, that looks superb!
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    @Calum @NINJA cheers lads. When you're rebuilding an engine that the previous owner "rebuilt" themselves you soon realise how many parts were missing, damaged or incorrect. Any help with the clutch washer ? Still need to do 1 more fowlers order. Pistons on its way 🙂
                                    • 2
                                      2stroketerry
                                      @Louis-James Great little engine your building and like seeing quality work that you do. When i put a 57mm stroke crank in mine didn't fit the washer under the PRIMARY DRIVE GEAR NUT so the so the nut had the maximum amount of threads to screw onto.
                                      The tabbed washer inside the splined washer is used to set the mainshaft endfloat on the clutch on some yamaha engines as they mix and match some gears inside the crankcase.
                                      Was thinking of using this on my new engine build but now decided to see what i can build using the Athena 170 kit so just bought them.
                                      https://www.ebay.co.uk/itm/YAMAHA-WR-200-3XP-4BF-NEW-SLEEVED-BIG-BORE-68mm-Cylinder-PISTON-3XP-11311-00-00/113185389112?hash=item1a5a5ffa38:g:3fwAAOSwEfBbZ3Je
                                      @Louis-James where did you get the final drive shaft from as need one for my new build. thanks
                                      • 2 2stroketerry
                                        Louis-DT-WRL
                                        Louis-DT-WRL
                                        @2stroketerry thanks man, I also ran a blaster 200 crankshaft on my original 200cc engine but wasn't happy with less gear meshing between the primary drive and clutch.
                                        With regards to the tab washer.. I can't see it on any exploded diagrams. What years use it?
                                        The final drive shaft I got brand new on eBay from Greece , £30 from memory, from Yamaha it's around £100
                                        • Irongamer727I
                                          Won't the 199cm3 text be an issue at the mot?
