  4. The wr200 3xp / dt125r 3bn hybrid 200cc engine no.2
43 Posts 10 Posters 14.0k Views 2 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Finally arrived
    3
    • Louis-DT-WRL Louis-DT-WR
      Finally arrived
      @Louis-James Very cranky!!! :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣
      • MiniaM
        MiniaM
        Minia
        Looking good! Then again everything you do looks outstanding to me.
        • MiniaM Minia
          Louis-DT-WRL
          Louis-DT-WRL
          @Minia thanks man. I like to do my best 😉
          • Louis-DT-WRL
            Louis-DT-WRL
            New powervalver but not genuine from Greece.
              @Louis-James If it's not genuine then what are the Yammy packets for??? :confused_face:
                Louis-DT-WRL
                Louis-DT-WRL
                @NINJA the powervalve is a reproduction. I have lots of brand new genuine parts that came from fowlers
                • Louis-DT-WRL
                  Louis-DT-WRL
                  What is this? I've not seen it before from memory clips inside the splined washer .
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    Cases bored out for the larger crankshaft
                      @Louis-James Sweet looking job dude. :clapping_hands:
                        WOw, that looks superb!
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @Calum @NINJA cheers lads. When you're rebuilding an engine that the previous owner "rebuilt" themselves you soon realise how many parts were missing, damaged or incorrect. Any help with the clutch washer ? Still need to do 1 more fowlers order. Pistons on its way 🙂
                          • 2
                            2stroketerry
                            @Louis-James Great little engine your building and like seeing quality work that you do. When i put a 57mm stroke crank in mine didn't fit the washer under the PRIMARY DRIVE GEAR NUT so the so the nut had the maximum amount of threads to screw onto.
                            The tabbed washer inside the splined washer is used to set the mainshaft endfloat on the clutch on some yamaha engines as they mix and match some gears inside the crankcase.
                            Was thinking of using this on my new engine build but now decided to see what i can build using the Athena 170 kit so just bought them.
                            https://www.ebay.co.uk/itm/YAMAHA-WR-200-3XP-4BF-NEW-SLEEVED-BIG-BORE-68mm-Cylinder-PISTON-3XP-11311-00-00/113185389112?hash=item1a5a5ffa38:g:3fwAAOSwEfBbZ3Je
                            @Louis-James where did you get the final drive shaft from as need one for my new build. thanks
                            • 2 2stroketerry
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @2stroketerry thanks man, I also ran a blaster 200 crankshaft on my original 200cc engine but wasn't happy with less gear meshing between the primary drive and clutch.
                              With regards to the tab washer.. I can't see it on any exploded diagrams. What years use it?
                              The final drive shaft I got brand new on eBay from Greece , £30 from memory, from Yamaha it's around £100
                              • Irongamer727I
                                Won't the 199cm3 text be an issue at the mot?
                                • 2
                                  2stroketerry
                                  @Irongamer727 I have an Athena 170cc kit with a 65mm piston in it that has 124cm3 cast on the side as well as Yamaha 5ML00 on it even though there is no such Yamaha cylinder number so no probelems with mot, police or insurance wise. The cylinder has a base spacer and has been skimmed to the correct compression ratio as well as the exhaust port and powervalve modified being 5mm wider, the transfer ports are raised by 1.5mm. Running the standard tm28 carb with power jet blocked and a 310 main jet it makes maximum power at 11,500 rpm and 37hp. No idea of top speed but running standard 16 57 gearing it goes straight off the clock in 5th gear but clock only goes to 80mph and will rev to maximum revs in 6th gear so it
                                  probably does about 100mph. Was going to gear it up but wheelies mental and when gets to 10,000 rpm it just goes mental with power.
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    Many MOT testers don't care tbh, but you could file the numbers off or do your big bike test.
                                    I think 2 strokes cc should be measured from above the exhaust port anyway 😉
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      Finally after 3 suppliers sending the wrong small end bearing... it's on.
                                      Forgot how beasty the piston looks in the 125 cases.
                                        #28
                                        @Louis-James Looks good - Which size piston is that dude???
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @NINJA it's standard wr200 size (66.80mm)
