  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 158.1k Views 5 Watching
  • Louis-DT-WRL Louis-DT-WR
    New horn
    New yz250 rear brake line
    New yz250 neon pink disc guard (matched shock spring)
    And the FMF fatty. Can't believe how much thicker the metal is to the DEP.
    Just the final bits and pieces need doing. Still waiting for the indicators and custom front brake hose.
    @Louis-James Looks mint bud - top job!!! :thumbs_up_light_skin_tone: :thumbs_up_dark_skin_tone: :thumbs_up_light_skin_tone:
    • Louis-DT-WRL
      Louis-DT-WRL
      Cheers lads
      • MiniaM
        MiniaM
        Minia
        I have an erection.
        • Louis-DT-WRL
          Louis-DT-WRL
          Does anyone know how many of these were made.. and different parts of the world quantities.
          All UK ones are imports.
          Does anyone know why they were only produced for 3/4years
          MiniaM 1 Reply Last reply
            MiniaM
            MiniaM
            Minia
            @Louis-James As far as I know the idea of the DT200WR was to build a trail bike that could compete and win in enduro races. Though obviously that brings the question as to why go halfway... also they were being made at the time when 2-stroke emissions were starting to be criticised and overall the appeal of 2-strokes was dying down considerably. Luckily in recent years it has picked up again. But I think back in the 90s there weren't many people who actually wanted to put the money in said bike.
            • MiniaM Minia
              Louis-DT-WRL
              Louis-DT-WRL
              @Minia that's a bit like what happened with turbo cars around the same time.. phased them out and whacked the insurance up... And now most cars have a turbo these days
              • Louis-DT-WRL
                Louis-DT-WRL
                Still waiting for the very last bits 😣
                But made a quick video (slideshow) https://youtu.be/kJED24hS3x4
                  @Louis-James Cool vid, I'm not sure about the choice of backing track tho!!! :grinning_face_with_smiling_eyes: :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat:
                    @Louis-James amazing
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      So today I did a test start to check all lights work.
                      Speedo and all lights on the new clocks work.
                      When I try the indicators....
                      the rear indicator stays on solid and the front does not light up , the clocks light stays on solid also...
                      This happens on both left and right hand side.
                      I think this is exactly what happened when my dtr relay went... Any thoughts? Hard to source the correct relay.
                      NINJAN CalumC 2 Replies Last reply
                        #103
                        @Louis-James Does the clock light disappear when you put it in gear?
                        I presume that you've checked all the wires, grounds, connectors, fuses etc. to ensure that there's nothing shorting out? No LED's all lights are regular bulbs???
                          @Louis-James Double check the wiring to make sure you haven't connected up the wrong sides. Sounds like a relay issue to me, I've had that a few times before.
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            All the looming was Mint and I cleaned all connections. The neutral light goes off when in gear... I'm pretty sure it's the regulator issue I had on my dtr
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @Calum that's what I think but it's a hard part to find. All earths were cleaned
                                I think I've had this before when only one of the indicators are connected.
                                • F
                                  What wattage lamps have you used in the indicators?
                                  When I changed mine to higher wattage i got the same symptoms you're describing.
                                    Louis-DT-WRL
                                    Louis-DT-WRL
                                    @finnerz89 they're original ones but new
                                      @Louis-James Check that the bulbs haven't gone and/or that the loom provides continutity throughout.
                                        Louis-DT-WRL
                                        Louis-DT-WRL
                                        @Calum cheers call, seems a bit of a coincidence that it's both sides
                                          @Louis-James Just make sure front right is connected to rear right and front left is connected to rear left.
