  4. Hmm now what (A Rebore!)
62 Posts 9 Posters 15.5k Views
  • P
    P
    Pablo13
    Yeah, once I've a chance to look at it in daylight, I'll pop covers and check the plug and see what gives.
    • P
      P
      Pablo13
      To rub it in my replacement swing arm chain guide turned up, so I stuck that on quickly and gave it a kick while it was out there. It didnt start but just from the feel of the kick I'd say its lacking in compression and dont feel smooth. It had a little backfire strangley too, hmm, Right now I'm thinking top end
      • P Pablo13
        @Pablo13 Worst case scenario, these bikes are a doddle to work on. So don't panic.
        • DanRacingD
          DanRacingD
          DanRacing
          To be honest it may be top end, or even bottom end. because with a 'lock up' of the engine the engine gets ALOT of stress, just like a heat seazure. actually the same stress from heat seazures on the crank and bearings. and not @Calum , the clutch doesn't do sh*t under hard breaking or even heat seazure.
          i've seen a dt125r seizing at about 140km/h, and even with grippy tyres(Pilot Street) the clutch didnt budge, he reacted quick and pulled in the clutch, saving him from eating asphalt, if you think correctly an emergency stop without clutch is a seizure the other way around. this can still break your piston, bearings, conrods etc.
          • DanRacingD DanRacing
            @DanRacing Yeah I think its a bit odd that applying the brakes would damage the engine. Sounds a bit far fetched to me.
            But it's easier and cheaper to whip the clutch cover off than it is to take the top end off.
            P 1 Reply Last reply
              P
              P
              Pablo13
              @Calum alt text
              :crying_face:
              Still not stripped, but my best guess is a snapped ring right now. That is what you get for forgetting to pull the clutch in I guess.
              • P Pablo13
                @Calum alt text
                :crying_face:
                @Pablo13 Not at all mate.
                The bike would have been tested heavily to slam the brakes on without engine failure.
                Something would have gone eventually.
                Either engine was due an overhaul, or it wasn't built within tolerance, or any number of reasons.
                You applying the brakes should not have killed the engine, that would be a shit design.
                • Irongamer727I
                  Little off topic, what compression in bars should a healthy dt125 have?
                    P
                    P
                    Pablo13
                    @Irongamer727 The manual indicates 6.8 πŸ˜‰
                      @Calum does he maybe mean he engine braked?
                        @declan Two strokes don't really engine brake though.
                        • P
                          P
                          Pablo13
                          Oooo err, its a bit of a mess in there, hang on....
                          • P
                            P
                            Pablo13
                            https://farm5.staticflickr.com/4829/32868499598_e399f7de9c_z.jpg
                            Piston is shagged, looks like something has got in or been in there for a while bouncing about, plus det marks, there is even a low spot on the crown from det. The Head I'm most concerned with hopefully it will tidy up. The bore isnt too sad at all, a light rebore should do it, new piston and see what happens lets hope πŸ™‚
                            • P Pablo13
                              @Pablo13 Yep that looks well fooked for-sure. I would also check the bottom end for any loose fragments floating about, just to be sure. Get one of these and give it a couple of swirls to pick up any debris floating around. πŸ˜‰
                              https://www.ebay.co.uk/itm/New-Flexible-Magnetic-Pick-Up-Long-Reach-Strong-Magnet-Grabber-Stick-w-Light-UK/113535422657?hash=item1a6f3d10c1β“‚mUSgt17pTEhDHzy-QODYJNQ:rk:33:pf:0
                                P
                                P
                                Pablo13
                                @NINJA I'll have a little fishing session with some magnets and see if I can find anything left behind.
                                • P Pablo13
                                  @Pablo13 I would be surprised if the heavy braking incident caused all that damage, by the looks of it your engine was in decline and had suffered some internal damage most likely from detonation, over an extended period of time. The incident was just the tip of the iceberg and the straw the finally broke the camel's back. You were dead lucky the engine maintained power and you were still able to ride her home. Sadly the price we all have to pay from owning a used bike and not knowing the true history of our pride n' joy.
                                    P
                                    P
                                    Pablo13
                                    @NINJA Yeah I agree. She is a French import, although it was the runt of the litter so to speak, and had expected stuff to go wrong and I guess the mileage is about right for a top end. Just surprised that any plugs I pulled looked fine and it always started first or second kick right up until that incident.
                                    I've run it on super while I've had it, so I guess it must have had some crap French fuel a while back and just managed to hold it together pootling about French lanes until I got my hands on it :grinning_face:
                                    On the upside this may well go to explaining why it wasn't too happy revving over 9k, so if it solves that issue at the same time, I'll be happy. 0.5mm oversize piston, small end and gaskets have been ordered today and the bore and head are at the machinists. Hoping for a quick turnaround :grimacing_face:
                                    • D
                                      Hard to tell in the pic but looks like the gudgeon pin circlip is missing? Unless you took it out before pic.
                                      J 1 Reply Last reply
                                        You will want to send that head off to be sorted out as well.
                                          @Calum yeah you could normally get away with a few dents but that’s completely savaged lol
