Messed up on my build need radiator advice
I ve put the dtr engine in a chopper frame the bottom radiator hose is lower than the radiator so I need to find a smaller radiator an mount in higher up. One thought was to use a pair of small twin radiators from a ktm sx 50 not sure if these will be too small
@dan28 I'm doing a similar build and 50 rads are very small I think 65 rads are more suited
@ninja thanks, it's my first time welding or building anything like this but I'm happy with how it's coming along
@ninja if you see my welds you would think different, maybe when it's running and riding I'll set something up
@declan looks good
You have loads of room if mount the radiator in front instead of at the side -
@dan28 I do without the exhaust it's a right hand radiator frame if I use a standard exhaust I'd have to get a different fuel tank and radiator plus seat set up so I'm going to build a simp me underslung exhaust
@dan28 I have ordered a new one should be here in a few days, I will measure it when it arrives for you.
They are tiny though.
@dan28 I was looking at one of those on ebay,it would likely me okay if room allows adding a radiator fan would help too
@declan said in Messed up on my build need radiator advice:
its alot smaller though an the fan for the gas gas rad is expensive even for a used one
i need to find out the sizes of the ktm sx 50 rads both together they should be equalivent to the dtr rad i think -
i need to find out the sizes of the ktm sx 50 rads both together they should be equalivent to the dtr rad i think@dan28
The manual says that the cooling works by βthermo ~ syphonic action in conjunction with the pumpβ, but basically when the coolant in the cylinder sleeve is hot enough to actuate the thermostat and open up, the pump will move it. I donβt know any other motor that has the radiator physically above the motor to rely on heat rising through convection
I guess Iβm saying that Iβd test run it with the rad mounted where you want it and see if it works. As long as the pump moves the coolant I donβt see any problem
I could be totally wrong though!
