1.1k Posts 26 Posters 686.0k Views
    @spookdog But that's what I'm saying, 2 smoke is enthusiasts. The youths are no longer interested in buying smokers. Maybe they never were, maybe people would just buy whatever was available and it just so happened to be that two strokes were the go to.
    My point still stands, youths aren't interested in smokers. It's now just an enthusiast thing.
    And Two Strokes still dominate the MX realm and they're making great strides with Two Strokes. Fuel Injection is now common place in the smoker scene. As well as AWD MX bikes 😛
    If you haven't checked out Cristinis AWD Motorcross bikes
    Two strokes are still very much here, but the demand is less because people don't actively buy them.
    https://www.christini.com/bikes/christini-awd-300
    This one is carb but EFI is now common place for KTM, Husky and the like!
    If you haven't checked out Cristini's AWD then go take a look 😃 Sick as.
    #46
    Mine own creation!...
    It looks super bright (& a bit white) in the pic (or just ‘washed out), or it did in the original! but there is a reflector lense from one of those cheap stick on reflectors bonded over the red led. It’s actually no brighter than the tail light and kinda mellow. Beats carrying a spare bulb on long night rides...
    Got it wired in with the front led spots...
    I call them dog lites 🐾
    S E 2 Replies Last reply
      #47
      Blown Again! 🌬
      Above is my new Athena gasket. I should of checked it closer before fitting. I didn’t see the scratch cause it was black with the coating. So this time it’s on me (again!! 😳 )
      You can see the leak path as a thin black line. The wetness in the head isn’t coolant, it’s unburnt oil (after a 70 mile ride!) Funny thing is the bike ran better after the head blew! The revs were crisp on pickup and really well ‘defined’. The rich mixture is another ongoing issue.
      This is the plug after the same journey.
        Blown Again! 🌬
        #48
        And for my next trick!
        This is within the last 70 miles...
        What causes this? Overcompression? Overheating? It’s only disappearing below the spark plug so I don’t think it’s detonation, but I’m no expert...
        Help!!...
          Help!!...
          wrote on last edited by DTR+NSR
          #49
          @spookdog that is detonation/pre ignition damage! My dt was running 225psi compression before I lowered it and that suffered no detonation. Normally it's down to a lean mixture.
          What heat range spark plug are you running?
          Also heard of excess carbon build up causing detonation.
            E
            E
            EdFrearson
            @spookdog I really like this, that blue looks gorgeous 😍
            CalumC S 2 Replies Last reply
            • E EdFrearson
              @edfrearson Endurance blue is definitely a favourite of mine.
              • D DTR+NSR
                @dtr-nsr
                NGK-R BR9EVX
                I was told it was ‘the equivalent’...
                • E EdFrearson
                  @edfrearson
                  Wasn’t my first choice! I also have every plastic panel (& tank) in mid/flat black.
                    @dtr-nsr
                    NGK-R BR9EVX
                    @spookdog yeah they run a 9 heat range plug as standard. Could be a combination of raised compression and lean mixture. Can run lean running to much oil even.
                    • D DTR+NSR
                      #55
                      There’s a thread somewhere that has the volume of 3mb & 3bn heads, even has the volume of the dome on (a Makita, done it again!) Mitaka! piston iirc. I can’t find it for looking. Can anyone please help?...
                      I did a fluid test on the 3mb head I have fitted and it was more than my spare 3bn head! So I really need 3rd party measures...
                        #56
                        Why am I only now hearing about o~ring heads! How long has this been viable tech?...
                        Am I missing out on anything else? Backwards compatible airflow metred injector inlets that run off of a simple lambda probe in the exhaust?! Perfect mixture all the time?!...
                        Ahhhhh 🤯
                          Ahhhhh 🤯
                          @spookdog Aprilia RS 125 has O-Ring head gasket.
                            You'll raise the compression converting to o ring. It's not hard to get the fueling reasonably good with the stock carb. Only time I've suffered lean issues, it was the base gasket that had gone, leaking in air.
                            • NottsbikerN
                              NottsbikerN
                              Could be an opportunity to take it off, remove the studs and lap them both flat again on a sheet of glass (or engineers table) to be 100% 🙂
                              Ignore me if you've already checked this issue 😉
                              • NottsbikerN Nottsbiker
                                #60
                                @nottsbiker
                                No daft questions bud. I haven’t recorded all my nightmares. But yeah, I’ve removed the studs and cleaned , checked and lapped. The second and third time the head blew are down to me, once using a gasket that had already been fitted, again when I used a copper gasket without fully understanding the process and not using spray sealant. The final time there was a scratch in the gasket that I didn’t expect or spot.
                                I’ve fitted another new Athena gasket and torqued it properly. I’ve fitted a newly lapped 3bn head that’s tip top condition, and weirdly higher compression (12.5~13ml) than the 3mb I was using (14ml)...
                                Every time I get somewhere another problem kicks in...
                                New Athena gasket torqued properly, I’ve disconnected the oil pump and gone premix. Rejetted the carb to standard and am going to take it from there. Square one again 🥴
                                  @nottsbiker
                                  This always bugged me! There is not supposed to be a ‘step’ there, eh?
                                  These are the cases I’m using now. I matched both sides before rebuilding. Could this be problematic? 2 different unmatched cases?...
                                    #62
                                    Same plug, different light...
                                        Cheers...
                                          Cheers...
