1.1k Posts 26 Posters 655.2k Views
    And for my next trick!
    This is within the last 70 miles...
    What causes this? Overcompression? Overheating? It’s only disappearing below the spark plug so I don’t think it’s detonation, but I’m no expert...
    Help!!...
    wrote on last edited by DTR+NSR
    #49
    @spookdog that is detonation/pre ignition damage! My dt was running 225psi compression before I lowered it and that suffered no detonation. Normally it's down to a lean mixture.
    What heat range spark plug are you running?
    Also heard of excess carbon build up causing detonation.
      Mine own creation!...
      It looks super bright (& a bit white) in the pic (or just ‘washed out), or it did in the original! but there is a reflector lense from one of those cheap stick on reflectors bonded over the red led. It’s actually no brighter than the tail light and kinda mellow. Beats carrying a spare bulb on long night rides...
      Got it wired in with the front led spots...
      I call them dog lites 🐾
      E
      E
      EdFrearson
      @spookdog I really like this, that blue looks gorgeous 😍
      CalumC S 2 Replies Last reply
      • E EdFrearson
        @edfrearson Endurance blue is definitely a favourite of mine.
        • D DTR+NSR
          @dtr-nsr
          NGK-R BR9EVX
          I was told it was ‘the equivalent’...
          • E EdFrearson
            @edfrearson
            Wasn’t my first choice! I also have every plastic panel (& tank) in mid/flat black.
              @dtr-nsr
              NGK-R BR9EVX
              @spookdog yeah they run a 9 heat range plug as standard. Could be a combination of raised compression and lean mixture. Can run lean running to much oil even.
              • D DTR+NSR
                #55
                There’s a thread somewhere that has the volume of 3mb & 3bn heads, even has the volume of the dome on (a Makita, done it again!) Mitaka! piston iirc. I can’t find it for looking. Can anyone please help?...
                I did a fluid test on the 3mb head I have fitted and it was more than my spare 3bn head! So I really need 3rd party measures...
                  #56
                  Why am I only now hearing about o~ring heads! How long has this been viable tech?...
                  Am I missing out on anything else? Backwards compatible airflow metred injector inlets that run off of a simple lambda probe in the exhaust?! Perfect mixture all the time?!...
                  Ahhhhh 🤯
                    Ahhhhh 🤯
                    @spookdog Aprilia RS 125 has O-Ring head gasket.
                      You'll raise the compression converting to o ring. It's not hard to get the fueling reasonably good with the stock carb. Only time I've suffered lean issues, it was the base gasket that had gone, leaking in air.
                      • NottsbikerN
                        NottsbikerN
                        Could be an opportunity to take it off, remove the studs and lap them both flat again on a sheet of glass (or engineers table) to be 100% 🙂
                        Ignore me if you've already checked this issue 😉
                        • NottsbikerN Nottsbiker
                          #60
                          @nottsbiker
                          No daft questions bud. I haven’t recorded all my nightmares. But yeah, I’ve removed the studs and cleaned , checked and lapped. The second and third time the head blew are down to me, once using a gasket that had already been fitted, again when I used a copper gasket without fully understanding the process and not using spray sealant. The final time there was a scratch in the gasket that I didn’t expect or spot.
                          I’ve fitted another new Athena gasket and torqued it properly. I’ve fitted a newly lapped 3bn head that’s tip top condition, and weirdly higher compression (12.5~13ml) than the 3mb I was using (14ml)...
                          Every time I get somewhere another problem kicks in...
                          New Athena gasket torqued properly, I’ve disconnected the oil pump and gone premix. Rejetted the carb to standard and am going to take it from there. Square one again 🥴
                            @nottsbiker
                            This always bugged me! There is not supposed to be a ‘step’ there, eh?
                            These are the cases I’m using now. I matched both sides before rebuilding. Could this be problematic? 2 different unmatched cases?...
                              #62
                              Same plug, different light...
                                  Cheers...
                                    Cheers...
                                      more variables:
                                      Found 2 new potential problems: 1, the wires for the sidestand kill switch may of been crushed by the seat. 2, I had to fit an inline fuel filter because of the state of the tanks inside, it has been creating a ‘locked in place’ air bubble. I don’t know if it’s been affecting flow at high revs and causing ‘bogging’. I have managed to finesse the air out by holding the tank up and keeping the fuel line vertical...
                                      My next test ride will tell...
                                      • declanD
                                        @spookdog air in the line is normal happens to a lot of bikes
                                          #68
                                          Best colour yet, ever! This is with the needle in the middle slot, also with the airscrew turned out 3 full turns. That is fully open when you look into the air jet!...
                                          Below:
                                          This is the plug that’s been brought up to full temp on tickover only, remember that this is with the airscrew wound full out...
                                          Wet n black! I don’t know why the standard 0.225 pilot jet is too rich on my particular bike, but it is. I have a 0.20 Mikuni jet I’m gonna try tomorrow. Wish me luck 👍
