1.1k Posts 26 Posters 655.3k Views
  • E EdFrearson
    @spookdog I really like this, that blue looks gorgeous 😍
    @edfrearson
    Wasn’t my first choice! I also have every plastic panel (& tank) in mid/flat black.
      @dtr-nsr
      NGK-R BR9EVX
      I was told it was ‘the equivalent’...
      @spookdog yeah they run a 9 heat range plug as standard. Could be a combination of raised compression and lean mixture. Can run lean running to much oil even.
      • D DTR+NSR
        #55
        There’s a thread somewhere that has the volume of 3mb & 3bn heads, even has the volume of the dome on (a Makita, done it again!) Mitaka! piston iirc. I can’t find it for looking. Can anyone please help?...
        I did a fluid test on the 3mb head I have fitted and it was more than my spare 3bn head! So I really need 3rd party measures...
          #56
          Why am I only now hearing about o~ring heads! How long has this been viable tech?...
          Am I missing out on anything else? Backwards compatible airflow metred injector inlets that run off of a simple lambda probe in the exhaust?! Perfect mixture all the time?!...
          Ahhhhh 🤯
            Ahhhhh 🤯
            @spookdog Aprilia RS 125 has O-Ring head gasket.
              You'll raise the compression converting to o ring. It's not hard to get the fueling reasonably good with the stock carb. Only time I've suffered lean issues, it was the base gasket that had gone, leaking in air.
              • NottsbikerN
                NottsbikerN
                Could be an opportunity to take it off, remove the studs and lap them both flat again on a sheet of glass (or engineers table) to be 100% 🙂
                Ignore me if you've already checked this issue 😉
                • NottsbikerN Nottsbiker
                  #60
                  @nottsbiker
                  No daft questions bud. I haven’t recorded all my nightmares. But yeah, I’ve removed the studs and cleaned , checked and lapped. The second and third time the head blew are down to me, once using a gasket that had already been fitted, again when I used a copper gasket without fully understanding the process and not using spray sealant. The final time there was a scratch in the gasket that I didn’t expect or spot.
                  I’ve fitted another new Athena gasket and torqued it properly. I’ve fitted a newly lapped 3bn head that’s tip top condition, and weirdly higher compression (12.5~13ml) than the 3mb I was using (14ml)...
                  Every time I get somewhere another problem kicks in...
                  New Athena gasket torqued properly, I’ve disconnected the oil pump and gone premix. Rejetted the carb to standard and am going to take it from there. Square one again 🥴
                    @nottsbiker
                    This always bugged me! There is not supposed to be a ‘step’ there, eh?
                    These are the cases I’m using now. I matched both sides before rebuilding. Could this be problematic? 2 different unmatched cases?...
                      #62
                      Same plug, different light...
                          Cheers...
                            Cheers...
                              more variables:
                              Found 2 new potential problems: 1, the wires for the sidestand kill switch may of been crushed by the seat. 2, I had to fit an inline fuel filter because of the state of the tanks inside, it has been creating a ‘locked in place’ air bubble. I don’t know if it’s been affecting flow at high revs and causing ‘bogging’. I have managed to finesse the air out by holding the tank up and keeping the fuel line vertical...
                              My next test ride will tell...
                              • declanD
                                @spookdog air in the line is normal happens to a lot of bikes
                                  #68
                                  Best colour yet, ever! This is with the needle in the middle slot, also with the airscrew turned out 3 full turns. That is fully open when you look into the air jet!...
                                  Below:
                                  This is the plug that’s been brought up to full temp on tickover only, remember that this is with the airscrew wound full out...
                                  Wet n black! I don’t know why the standard 0.225 pilot jet is too rich on my particular bike, but it is. I have a 0.20 Mikuni jet I’m gonna try tomorrow. Wish me luck 👍
                                    Below:
                                    Found another potential yesterday, the long breather pipe that hangs down on the kickstart side leads to a hole at the top of the ‘tube’ that the needle jet fits into. (I guess it’s to let the fuel level go up and down inside the jet, equalising the pressure, maybe? Fluid won’t rise in a closed environment, like an upside down cup in water) where the slide housing joins there is potential for mischief. My gasket is so compressed I have to use sealant. I’ve tried hermatite red and silicon. The silicon was kinda vulcanised by the fuel at the bottom of the slide where the breather pipe join is. So I’m going with the red but I’ve had so many inconsistencies I really want a new gasket. Anyone know of?...
                                    I think the vent has been causing some of the mid throttle bogging and inconsistency...
                                      Went down to a .20 pilot and it still ran wet plug with the airscrew fully out! Since put in a 17.5 and it ticks over well, the plug is still slightly black but not dripping wet at 1.5 turns...
                                      The proof will be in a test ride though...
                                      I’m using this thread as a memory diary, if I don’t write it down I forget!
                                        It’s running good on the 17.5 pilot at 1/4 turn out of the airscrew. Did a 70 mile test ride with loads of slow running, plug is dry, at last!! 🤪
                                          Has anyone else had overheating problems the last couple hot days?
