  3. DTX
  4. Dtx Project Codename Moneypit
77 Posts 13 Posters 35.6k Views 2 Watching
  • ZrakoZ
    ZrakoZ
    Zrako
    Small update . Engine rebuilt and frame finally came back from powdercoating. Not sure if I love the change but have to deal with it now 😂 0_1491671835721_20170407_180013.jpg
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    3
    • ZrakoZ Zrako
      @Zrako Yes mate that is looking lovely!
      • ZrakoZ Zrako
        @Zrako If it's not as you originally envisaged, most of it will be hidden anyways, so it's all good really!!! 😉
        • G
          G
          gareth_iowc
          Same frame colour as me. I like it 🙂
          DT125R 2000
          DRZ400 2006
          Golf Mk3 20v Turbo 1996
          • ZrakoZ
            ZrakoZ
            Zrako
            Shame I have to wait till monday to build it up as I work all weekend now. Still no bearings for swingarm as I need all seals and the needle bearing shafts...😓
            • Louis-DT-WRL
              Louis-DT-WRL
              The wr200 one if I remember rightly is a direct fit with the correct links.
              Dt200r is also aluminium but not as chunky
              • ZrakoZ
                ZrakoZ
                Zrako
                Well , building it up slowly and ended up at coolant section so far. Just want to be 100% sure - the hose from radiator that going to expansion tank joins on bottom of tank and the top one is breather hose that ends up under engine? Forgot what way it was before... 😶
                • ZrakoZ Zrako
                  @Zrako If you think about it, it's obvious.
                  If it fed in through the top it would immediately drip out.
                  So you feed it in through the bottom, if it feeds in too much the overflow at the top will allow it drip out, usually an indication when the head gasket has failed.
                  So yes, from the radiator to the bottom of the expansion bottle.
                  • ZrakoZ
                    ZrakoZ
                    Zrako
                    wrote on last edited by Zrako
                    #41
                    Yeah thanks mate. Just wasnt sure if the top one should fit somewhere or just opened under the bike.
                    • ZrakoZ
                      ZrakoZ
                      Zrako
                      Well , bike is like 95% finished. Bearings sorted from wemoto , all new shiny stainless fasteners everywhere. Tried to exchange every possible nut bolt and washer. Just waiting for new chain
                      link text
                      First start of the bike , changed the engine oil lines for clear ones too and they are awesome and usefull. My pump needs bled and small coolant leak from top of the head. Hopefully only carb warming screw needs the copper washer 🤔
                      If you see anything on the video strange and suspicious please let me know 😊.
                      • ZrakoZ Zrako
                        link text
                        @Zrako Looking good thus far bud!!! 👍
                        • MightymanM
                          So you went with the stock swing arm in the end? Looking nice!
                          ZrakoZ 1 Reply Last reply
                          • MightymanM Mightyman
                            ZrakoZ
                            ZrakoZ
                            Zrako
                            @Mightyman yes , too much hassle with it so keep it stock. Defo need the forks as the stanchions are badly dented. Maybe leave it for winter... btw no leaks at all now 🤗
                            • ZrakoZ
                              ZrakoZ
                              Zrako
                              #46
                              Not sure if it suppose to sound like this. What you guys think? I mean the sound when I rev it its strange . New piston , rings , conrod , bearings...
                              https://youtu.be/cleKkIbDTeI
                              • F
                                Is your starter still running?
                                ZrakoZ MightymanM 2 Replies Last reply
                                  ZrakoZ
                                  ZrakoZ
                                  Zrako
                                  @finnerz89 thats a good question .need to check that . Thanks
                                    @finnerz89 starter motor is a good shout. That is an odd sound.
                                    • ZrakoZ Zrako
                                      @Zrako That's not running the snorkel is it?
                                      Is the powervalve working?
                                        ZrakoZ
                                        ZrakoZ
                                        Zrako
                                        @Calum the previous owner decided to cut it out for some strange reasons. A small bit left of the snorkel on the filter housing. The powervalve resets nice and freely when I turn the key. Should I take the exp. pipe off and inspect it ? Im just cleaned it from carbon and put it back on right order as per haynes manual and set the cable tension...
                                        • ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          ... bike wont start up without stator removed from rotor. Neither kickstarted
