  3. DTX
  4. Dtx Project Codename Moneypit
77 Posts 13 Posters 35.6k Views 2 Watching
  • ZrakoZ
    ZrakoZ
    Zrako
    Guys , desperately searching internet for the complete set of swingarm bearings , pins , thrust washers , bearings . Heeelp please ☺
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • ZrakoZ Zrako
      @Zrako just measure them and go to simplybearings
      ZrakoZ 1 Reply Last reply
        ZrakoZ
        ZrakoZ
        Zrako
        @Calum will do mate . Im thought that Im found one but its for 78-81 model.
          As said I got all mine off simply bearings no problem. Saved loads of money as well!
          • ZrakoZ
            ZrakoZ
            Zrako
            Small update . Engine rebuilt and frame finally came back from powdercoating. Not sure if I love the change but have to deal with it now 😂 0_1491671835721_20170407_180013.jpg
            3
            • ZrakoZ Zrako
              @Zrako Yes mate that is looking lovely!
              • ZrakoZ Zrako
                @Zrako If it's not as you originally envisaged, most of it will be hidden anyways, so it's all good really!!! 😉
                • G
                  G
                  gareth_iowc
                  Same frame colour as me. I like it 🙂
                  DT125R 2000
                  DRZ400 2006
                  Golf Mk3 20v Turbo 1996
                  • ZrakoZ
                    ZrakoZ
                    Zrako
                    Shame I have to wait till monday to build it up as I work all weekend now. Still no bearings for swingarm as I need all seals and the needle bearing shafts...😓
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      The wr200 one if I remember rightly is a direct fit with the correct links.
                      Dt200r is also aluminium but not as chunky
                      • ZrakoZ
                        ZrakoZ
                        Zrako
                        Well , building it up slowly and ended up at coolant section so far. Just want to be 100% sure - the hose from radiator that going to expansion tank joins on bottom of tank and the top one is breather hose that ends up under engine? Forgot what way it was before... 😶
                        • ZrakoZ Zrako
                          @Zrako If you think about it, it's obvious.
                          If it fed in through the top it would immediately drip out.
                          So you feed it in through the bottom, if it feeds in too much the overflow at the top will allow it drip out, usually an indication when the head gasket has failed.
                          So yes, from the radiator to the bottom of the expansion bottle.
                          • ZrakoZ
                            ZrakoZ
                            Zrako
                            wrote on last edited by Zrako
                            #41
                            Yeah thanks mate. Just wasnt sure if the top one should fit somewhere or just opened under the bike.
                            • ZrakoZ
                              ZrakoZ
                              Zrako
                              Well , bike is like 95% finished. Bearings sorted from wemoto , all new shiny stainless fasteners everywhere. Tried to exchange every possible nut bolt and washer. Just waiting for new chain
                              link text
                              First start of the bike , changed the engine oil lines for clear ones too and they are awesome and usefull. My pump needs bled and small coolant leak from top of the head. Hopefully only carb warming screw needs the copper washer 🤔
                              If you see anything on the video strange and suspicious please let me know 😊.
                              • ZrakoZ Zrako
                                link text
                                @Zrako Looking good thus far bud!!! 👍
                                • MightymanM
                                  So you went with the stock swing arm in the end? Looking nice!
                                  • MightymanM Mightyman
                                    ZrakoZ
                                    ZrakoZ
                                    Zrako
                                    @Mightyman yes , too much hassle with it so keep it stock. Defo need the forks as the stanchions are badly dented. Maybe leave it for winter... btw no leaks at all now 🤗
                                    • ZrakoZ
                                      ZrakoZ
                                      Zrako
                                      #46
                                      Not sure if it suppose to sound like this. What you guys think? I mean the sound when I rev it its strange . New piston , rings , conrod , bearings...
                                      https://youtu.be/cleKkIbDTeI
                                      • F
                                        Is your starter still running?
                                        ZrakoZ MightymanM 2 Replies Last reply
                                          ZrakoZ
                                          ZrakoZ
                                          Zrako
                                          @finnerz89 thats a good question .need to check that . Thanks
