tuningdtryamaha2003wr200
254 Posts 25 Posters 243.6k Views 6 Watching
  • Louis-DT-WRL Louis-DT-WR
    Old video to show previous work from the old forum
    https://youtu.be/OPPg6yybNCo
    Old video of 200cc conversion
    https://youtu.be/4arPAsoEZaE
    More recent video.
    https://youtu.be/cDtMUnvHCIk
    More is constantly being done to this project 🙂
    Louis-DT-WRL
    Louis-DT-WRL
    • Louis-DT-WRL
      Louis-DT-WRL
      • Louis-DT-WRL
        Louis-DT-WRL
        • Louis-DT-WRL
          Louis-DT-WRL
            Sick project!
            • Biker_123B
              Biker_123B
              Biker_123
              This bike is looking stunning @Louis-James !!! 😍 good job
              Every problem has a solution
              • Leftyno1L
                Leftyno1L
                Leftyno1
                Respect on the project great work, is the zeeltronic as good as everyone says, have heard only good things.
                • Louis-DT-WRL
                  Louis-DT-WRL
                  Thanks guys, yes the zeeltronic is amazing. I was the one who helped zeeltronic make a cdi for the dt125r 2003 with my specs, data and wiring with the connector blocks pictures. Really helped set the correct powervalve curve and limits with my wr200 top end and using the dt125r stator plate, also the ignition timing.
                  CalumC aidan1996A 2 Replies Last reply
                    @Louis-James I remember the commotion on the last site. Respect for that mate that's awesome.
                    • ConnorDTRC
                      ConnorDTRC
                      ConnorDTR
                      That is ridiculously clean! Looking good
                        Louis-DT-WRL
                        Louis-DT-WRL
                        @Calum thanks. I've seen yours too and it's sweet
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          The 200cc part
                          Crank cases bored to fit the wr200 crankshaft
                          Enlarging the transfer ports
                          • Louis-DT-WRL
                            Louis-DT-WRL
                              The 200cc part
                              Louis-DT-WRL
                              Louis-DT-WRL
                              Bought this off Gumtree, all threads stripped, I had to use a m10 helicoil kit on the head studs. The powervalve was damaged so I bought a brand new one at a later date. This is the nickasil bore version and didn't need a re-bore luckily so I bought a new wiseco piston and a brand-new wr200 crankshaft, originally I bought a wiseco yamaha blaster one which did fit in with modifications to the primary drive gear but I wasn't happy with it so I swapped it.
                                Louis-DT-WRL
                                Louis-DT-WRL
                                A few comparison pics
                                The new piston
                                Powdercoated in my favorite colours
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  Old vs new haha
                                  Née crank bearings
                                  Test fit (I later had the crankcases sprayed) alt text
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    Here's a close up of the wr200s boost ports (before I cleaned them) note: also bought a brand new powervalve afterwards as the dowl holes were sloppy.
                                    Here's it built up (not using the tmx30 anymore)
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      My custom intake upgrade
                                      Vforce v3 reed block - mikuni tm34ss carburetor
                                      I cut the spigot off the reed block and centralized the flow to match the original and cut bolt holes to match
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        I cut off the flow guide from the manifold (this is not a restrictor, people think it is but it isn't, removing it will lose performance) I do not need this as my reed block comes with one fitted.
                                        • Louis-DT-WRL
                                          Louis-DT-WRL
                                          #21
                                          See what I mean?
