tuningdtryamaha2003wr200
254 Posts 25 Posters 237.2k Views 6 Watching
  • Leftyno1L
    Leftyno1L
    Leftyno1
    Respect on the project great work, is the zeeltronic as good as everyone says, have heard only good things.
    • Louis-DT-WRL
      Louis-DT-WRL
      Thanks guys, yes the zeeltronic is amazing. I was the one who helped zeeltronic make a cdi for the dt125r 2003 with my specs, data and wiring with the connector blocks pictures. Really helped set the correct powervalve curve and limits with my wr200 top end and using the dt125r stator plate, also the ignition timing.
      CalumC aidan1996A 2 Replies Last reply
      • Louis-DT-WRL Louis-DT-WR
        @Louis-James I remember the commotion on the last site. Respect for that mate that's awesome.
        • ConnorDTRC
          ConnorDTRC
          ConnorDTR
          That is ridiculously clean! Looking good
            Louis-DT-WRL
            Louis-DT-WRL
            @Calum thanks. I've seen yours too and it's sweet
            • Louis-DT-WRL
              Louis-DT-WRL
              The 200cc part
              Crank cases bored to fit the wr200 crankshaft
              Enlarging the transfer ports
              • Louis-DT-WRL
                Louis-DT-WRL
                  The 200cc part
                  Louis-DT-WRL
                  Louis-DT-WRL
                  Bought this off Gumtree, all threads stripped, I had to use a m10 helicoil kit on the head studs. The powervalve was damaged so I bought a brand new one at a later date. This is the nickasil bore version and didn't need a re-bore luckily so I bought a new wiseco piston and a brand-new wr200 crankshaft, originally I bought a wiseco yamaha blaster one which did fit in with modifications to the primary drive gear but I wasn't happy with it so I swapped it.
                    Louis-DT-WRL
                    Louis-DT-WRL
                    A few comparison pics
                    The new piston
                    Powdercoated in my favorite colours
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      Old vs new haha
                      Née crank bearings
                      Test fit (I later had the crankcases sprayed) alt text
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        Here's a close up of the wr200s boost ports (before I cleaned them) note: also bought a brand new powervalve afterwards as the dowl holes were sloppy.
                        Here's it built up (not using the tmx30 anymore)
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          My custom intake upgrade
                          Vforce v3 reed block - mikuni tm34ss carburetor
                          I cut the spigot off the reed block and centralized the flow to match the original and cut bolt holes to match
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            I cut off the flow guide from the manifold (this is not a restrictor, people think it is but it isn't, removing it will lose performance) I do not need this as my reed block comes with one fitted.
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              #21
                              See what I mean?
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                #22
                                I used a tm34ss from a Aprilia rs250
                                Note the angle spigots, this makes fitting a lot more easy and the float bowl stays level
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  #23
                                  I had to carefully enlarge the manifolds bore to 34mm and also increase the size to fit the carburetor in, I managed to add a grip step to match the carburetor (this adds more stability.)
                                  Because the size of the carbs inlet I had to compromise. I tried a yz250 evos rubber boot which almost was perfect but it kept breaking due to age.
                                  So plan B was like this:
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    #24
                                    It wasn't the nicest way, but it works well
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      #25
                                      I also removed the top of the airbox previous to this mod
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        #26
                                        A few pictures of it fitted.
                                        • Louis-DT-WRL
                                          Louis-DT-WRL
                                          I had to blank off the vacuum pipes on the carb and I also adjusted the autolube because of all my modifications
