tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    Old vs new haha
    Née crank bearings
    Test fit (I later had the crankcases sprayed) alt text
    • Louis-DT-WRL
      Louis-DT-WRL
      Here's a close up of the wr200s boost ports (before I cleaned them) note: also bought a brand new powervalve afterwards as the dowl holes were sloppy.
      Here's it built up (not using the tmx30 anymore)
      • Louis-DT-WRL
        Louis-DT-WRL
        My custom intake upgrade
        Vforce v3 reed block - mikuni tm34ss carburetor
        I cut the spigot off the reed block and centralized the flow to match the original and cut bolt holes to match
        • Louis-DT-WRL
          Louis-DT-WRL
          I cut off the flow guide from the manifold (this is not a restrictor, people think it is but it isn't, removing it will lose performance) I do not need this as my reed block comes with one fitted.
          • Louis-DT-WRL
            Louis-DT-WRL
            #21
            See what I mean?
            • Louis-DT-WRL
              Louis-DT-WRL
              #22
              I used a tm34ss from a Aprilia rs250
              Note the angle spigots, this makes fitting a lot more easy and the float bowl stays level
              • Louis-DT-WRL
                Louis-DT-WRL
                #23
                I had to carefully enlarge the manifolds bore to 34mm and also increase the size to fit the carburetor in, I managed to add a grip step to match the carburetor (this adds more stability.)
                Because the size of the carbs inlet I had to compromise. I tried a yz250 evos rubber boot which almost was perfect but it kept breaking due to age.
                So plan B was like this:
                • Louis-DT-WRL
                  Louis-DT-WRL
                  #24
                  It wasn't the nicest way, but it works well
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    #25
                    I also removed the top of the airbox previous to this mod
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      #26
                      A few pictures of it fitted.
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        I had to blank off the vacuum pipes on the carb and I also adjusted the autolube because of all my modifications
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          #28
                          I forgot to say that my DEP exhaust is for a wr200, so it's perfect for my bike. I had to make custom fixing and rubber mounts. Note how long the silencer was hahaha
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            #29
                            Dt125r dep and wr200 dep together. It looks like I'm punching it, can't remember the reason for that 😆
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              #30
                              The silencer was a bit long 😉
                              So I cut it down, I'm after a different end cap if anyone has one spare?
                              • Biker_123B
                                Biker_123B
                                Biker_123
                                This bike really is amazing and I'm totally enjoying reading through this 😃. I'm guessing all these upgrades must have cost a lot of money ,definitely worth it though lol if this was my bike I'd be scared to use it incase it got dirt on it or a scratch 😁
                                Every problem has a solution
                                • Biker_123B Biker_123
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  @Biker_123 thanks a lot, not as much as you would think as I got most of the parts trade and I know a few engineers. And I sold a lot of the old parts for decent money.
                                  Stay tuned 😉
                                    wrote on last edited by Darty
                                    #33
                                    Sweet ride. Beast. Did you try the 3XP 200 top end with a 125 crank before? I know its a longer stroke with the 200 series. Which one do you think was lighter? I got a WR200 top end and 200R bottom end and gearbox replacement for a rebuild but I won't have a chance to compare the two.
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      No other won't run with a 125 crank it's like 8mm shorter stroke, also a dt200r has 0.7mm shorter stroke than a wr200 if I remember right. If you want to sell your top end I could build another engine 😉
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        #35
                                        And ofcourse I had zeeltronic make the first DT125R CDI for me and for all my help I only had to pay for the handheld reprogrammer
                                        This was perfect for my project to set the powervalve limits and curve.
                                        Also great for ignition timing.
                                        Although they did wire it wrong originally and the powervalve ran backwards 😆
                                        But soon sorted it.
                                          Safe, yeah 200s are like 57mm, 125s at 50mm. just wondered if you had built up a crank shaft assembly before hand. I wanted to start from scratch with a crank. Yeah had my suspicions about a DT200R crank in a WR barrel. I'll see what I can do with mine still.
                                          This stuffs getting hard to get.
