tuningdtryamaha2003wr200
254 Posts 25 Posters 240.5k Views 6 Watching
  • Louis-DT-WRL
    Louis-DT-WRL
    The 200cc part
    Crank cases bored to fit the wr200 crankshaft
    Enlarging the transfer ports
    • Louis-DT-WRL
      Louis-DT-WRL
      • Louis-DT-WRL Louis-DT-WR
        The 200cc part
        Louis-DT-WRL
        Louis-DT-WRL
        Bought this off Gumtree, all threads stripped, I had to use a m10 helicoil kit on the head studs. The powervalve was damaged so I bought a brand new one at a later date. This is the nickasil bore version and didn't need a re-bore luckily so I bought a new wiseco piston and a brand-new wr200 crankshaft, originally I bought a wiseco yamaha blaster one which did fit in with modifications to the primary drive gear but I wasn't happy with it so I swapped it.
          Louis-DT-WRL
          Louis-DT-WRL
          A few comparison pics
          The new piston
          Powdercoated in my favorite colours
          • Louis-DT-WRL
            Louis-DT-WRL
            Old vs new haha
            Née crank bearings
            Test fit (I later had the crankcases sprayed) alt text
            • Louis-DT-WRL
              Louis-DT-WRL
              Here's a close up of the wr200s boost ports (before I cleaned them) note: also bought a brand new powervalve afterwards as the dowl holes were sloppy.
              Here's it built up (not using the tmx30 anymore)
              • Louis-DT-WRL
                Louis-DT-WRL
                My custom intake upgrade
                Vforce v3 reed block - mikuni tm34ss carburetor
                I cut the spigot off the reed block and centralized the flow to match the original and cut bolt holes to match
                • Louis-DT-WRL
                  Louis-DT-WRL
                  I cut off the flow guide from the manifold (this is not a restrictor, people think it is but it isn't, removing it will lose performance) I do not need this as my reed block comes with one fitted.
                  • Louis-DT-WRL
                    Louis-DT-WRL
                    #21
                    See what I mean?
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      #22
                      I used a tm34ss from a Aprilia rs250
                      Note the angle spigots, this makes fitting a lot more easy and the float bowl stays level
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        #23
                        I had to carefully enlarge the manifolds bore to 34mm and also increase the size to fit the carburetor in, I managed to add a grip step to match the carburetor (this adds more stability.)
                        Because the size of the carbs inlet I had to compromise. I tried a yz250 evos rubber boot which almost was perfect but it kept breaking due to age.
                        So plan B was like this:
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          #24
                          It wasn't the nicest way, but it works well
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            #25
                            I also removed the top of the airbox previous to this mod
                            • Louis-DT-WRL
                              Louis-DT-WRL
                              #26
                              A few pictures of it fitted.
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                I had to blank off the vacuum pipes on the carb and I also adjusted the autolube because of all my modifications
                                • Louis-DT-WRL
                                  Louis-DT-WRL
                                  #28
                                  I forgot to say that my DEP exhaust is for a wr200, so it's perfect for my bike. I had to make custom fixing and rubber mounts. Note how long the silencer was hahaha
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    #29
                                    Dt125r dep and wr200 dep together. It looks like I'm punching it, can't remember the reason for that 😆
                                    • Louis-DT-WRL
                                      Louis-DT-WRL
                                      #30
                                      The silencer was a bit long 😉
                                      So I cut it down, I'm after a different end cap if anyone has one spare?
                                      • Biker_123B
                                        Biker_123B
                                        Biker_123
                                        This bike really is amazing and I'm totally enjoying reading through this 😃. I'm guessing all these upgrades must have cost a lot of money ,definitely worth it though lol if this was my bike I'd be scared to use it incase it got dirt on it or a scratch 😁
                                        Every problem has a solution
                                        • Biker_123B Biker_123
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          @Biker_123 thanks a lot, not as much as you would think as I got most of the parts trade and I know a few engineers. And I sold a lot of the old parts for decent money.
                                          Stay tuned 😉
