PIC HEAVY (wr200 topend , zeeltronic, tm34ss carb, V-force reed block,Larger radiator,DEP PIPE,)
Bought this off Gumtree, all threads stripped, I had to use a m10 helicoil kit on the head studs. The powervalve was damaged so I bought a brand new one at a later date. This is the nickasil bore version and didn't need a re-bore luckily so I bought a new wiseco piston and a brand-new wr200 crankshaft, originally I bought a wiseco yamaha blaster one which did fit in with modifications to the primary drive gear but I wasn't happy with it so I swapped it.
A few comparison pics
The new piston
Powdercoated in my favorite colours
Old vs new haha
Née crank bearings
Test fit (I later had the crankcases sprayed)
Here's a close up of the wr200s boost ports (before I cleaned them) note: also bought a brand new powervalve afterwards as the dowl holes were sloppy.
Here's it built up (not using the tmx30 anymore)
My custom intake upgrade
Vforce v3 reed block - mikuni tm34ss carburetor
I cut the spigot off the reed block and centralized the flow to match the original and cut bolt holes to match
I cut off the flow guide from the manifold (this is not a restrictor, people think it is but it isn't, removing it will lose performance) I do not need this as my reed block comes with one fitted.
See what I mean?
I used a tm34ss from a Aprilia rs250
Note the angle spigots, this makes fitting a lot more easy and the float bowl stays level
I had to carefully enlarge the manifolds bore to 34mm and also increase the size to fit the carburetor in, I managed to add a grip step to match the carburetor (this adds more stability.)
Because the size of the carbs inlet I had to compromise. I tried a yz250 evos rubber boot which almost was perfect but it kept breaking due to age.
So plan B was like this:
It wasn't the nicest way, but it works well
I also removed the top of the airbox previous to this mod
A few pictures of it fitted.
I had to blank off the vacuum pipes on the carb and I also adjusted the autolube because of all my modifications
I forgot to say that my DEP exhaust is for a wr200, so it's perfect for my bike. I had to make custom fixing and rubber mounts. Note how long the silencer was hahaha
Dt125r dep and wr200 dep together. It looks like I'm punching it, can't remember the reason for that :laughing:
The silencer was a bit long :wink:
So I cut it down, I'm after a different end cap if anyone has one spare?
This bike really is amazing and I'm totally enjoying reading through this 😃. I'm guessing all these upgrades must have cost a lot of money ,definitely worth it though lol if this was my bike I'd be scared to use it incase it got dirt on it or a scratch 😁
@Biker_123 thanks a lot, not as much as you would think as I got most of the parts trade and I know a few engineers. And I sold a lot of the old parts for decent money.
Stay tuned ;)
Sweet ride. Beast. Did you try the 3XP 200 top end with a 125 crank before? I know its a longer stroke with the 200 series. Which one do you think was lighter? I got a WR200 top end and 200R bottom end and gearbox replacement for a rebuild but I won't have a chance to compare the two.
