portingignitech4dldtrwr200
135 Posts 27 Posters 140.9k Views 6 Watching
    @andrew1680 Plug and play bud
      wrote on last edited by Darty
      #67
      Have not touched this in months...
      Got it Powder Coated back in January, glad it's done,
      Cleaned up all the threads, very satisfying.
      Pro Taper - Henry Reed bend. NOT Kevin Windham's - much to my disgust.
      It's a shame it had to come apart.
      • MightymanM
        Bit of an odd question, but what tap and die set do you have? My cheapy one is terrible, doesn't have any of the right sizes!
        DartyD 1 Reply Last reply
        • MightymanM Mightyman
          @Mightyman I just used 'Dormer' M6 and M8 Metric Coarse (Straight flute) taps. 1mm pitch I believe. Standard stuff, they seem good quality.
          • Louis-DT-WRL
            Louis-DT-WRL
            Great project there, I see you trying a lot of the things I did.
            I had a tm32 carb once upon a time, the only problem was it would overflow because the angle it sits, and if you adjust the floats, it didn't always get enough fuel.
            Also see you're using a YZ airbox to carb boot like I did,.
            • ZrakoZ
              ZrakoZ
              Zrako
              What shock is that mate?
              1979 Jawa Mustang 50
              2003 Gilera DNA 125 R.I.P
              2015 Keeway TX 125 SM
              2006 Yamaha DT 125 X
                #72
                @Zrako Its from a 1987' YZ490.
                Minor Update bits
                Hand sanded and Polished.
                Ducati 899 Brembo Master Cylinder - 5 minutes to splice the old DTR Brake switch plug on, same coloured wires to.
                Yamaha TDM900-5PS Brembo Master cylinder - Fits perfect. Frame mounts needs drilling out to M8 is all.
                Thought I'd post some engine picys.
                134cc TZR 4DL Topend - Mikuni TM32.
                1987' YZ125 Airboot - The original DTR Airbox needs only simple modification.
                @Louis-James Cheers man, I know what you mean about using any other Carb except a TMSS with an angled Venturi. I couldn't run the TM32 to start with.
                I'll use the WR200 Inlet instead, that solves the fitment issues, I use a Reed spacer on the standard inlet and that makes it work well.
                The WR200 Inlet helps to level out the Carb to something pretty good.
                Louis-DT-WRL NINJAN 3 Replies Last reply
                  Minor Update bits
                  Louis-DT-WRL
                  Louis-DT-WRL
                  @Darty that's a good plan, I had thought of a wr200 manifold but that was before I knew you could get new parts for such old bikes haha.
                  There are a few pictures of the YZ airbox rubber Installed on my bike on the old forum somewhere
                    Minor Update bits
                    @Darty Looking damn good bud!!! 👍
                    • A
                      A
                      andrewj1680
                      The wr200 manifold won't fit unless you cut the back off it as it's too big to fit the dt case's also the holes look to be in slightly different places
                        Minor Update bits
                        @Darty Did you just hand sand and hand polish the swing arm to get that result? Using fine grades all the time I suspect? Looks damn good if you did? How long did it take you to get that good of a result bud???
                          @andrewj1680 I know it's not perfect, cutting stuffers off is a big compromise to inlet air speed when using the standard Reed block.
                          So to avoid that I'm using a VFORCE Reed block, still have to modify the mounts and cut the stuffers off, but the VFORCE will take care of the inlet volume and should give much better Midrange,
                          @CYBER-NINJA Actually I did use a Orbital sander with 120 - 400 grit because these older swingarms have huge extrusion depressions under the thick paint, it looked very clumsy before, alot of material had to come away.
                          hand sanded in between and to Wet n Dry 600-800 grit, 1200 would be too anal.
                            @Darty Came out damn good tho in the end, well worth the time and effort IMO. 👍
                            I need to do the same on my MX, I started with some wet & dry just to test it out, TBC..................
                              @CYBER-NINJA Thank you very much,
                              It was about a days work, very satisfying to finish
                                @Darty Yeah lotsa elbow grease know doubt. I find using a good paint stripper with some steel wool works really well and also limits the scratches, then some wet & dry to smooth it all off, before you start on the polishing. All in all that method works very well and also it makes short work of the polishing. 😉
                                • A
                                  A
                                  andrewj1680
                                  0_1494210331154_Screenshot_2017-05-08-03-13-33-1.png 0_1494210363397_Screenshot_2017-05-08-03-13-45-1.png
                                  I did the whole polishing thing when I first started building my cr but by the time I finished I had decided I didn't wanna polish after every ride so I powder coated it black instead, did look the part tho
                                  DartyD NINJAN 2 Replies Last reply
                                  • A andrewj1680
                                    #82
                                    @andrewj1680 Bang on! That would of looked mint, it's a shame alloy has to oxidise so quickly,
                                    • A andrewj1680
                                      @andrewj1680 Oh man, that sure looks damn sweet, and such a shame to do all that work and then get all that lovely shiny metal blacked out. But hey-hoo I get why and it was your choice.
                                      A 1 Reply Last reply
                                        A
                                        A
                                        andrewj1680
                                        @CYBER-NINJA I preferred the polished look but I'd of spent more time polishing it than riding it every time I took it out, Can you imagine trying to avoid every puddle you came across lol that wasn't for me if it's there I'm gonna ride it
                                          (6mm Stainless Steel - Brass 13-14mm spacers)
                                          I made DXF files for Waterjet cutting - for a Stainless Calliper adapter and spacers for a SM conversion using the 'YZF125' Brembo calliper.
                                          If there are a few members here looking to do SM conversions, I could get a few kits together with bolts,
                                          Just a limited run as I have the time for the moment.
