  4. DT 125 R '88... New project
89 Posts 11 Posters 36.5k Views 1 Watching
  • J jgr72
    Isn't DT200R engine totally different than DR125R? To be honest, I was looking for KMX200 / DT200, but those are so rare here in Finland... I used to have XT600 many years ago, but it was quite heavy for me...
    Well, I might not be so good to express myself 😄 I wan't to keep it look a like original... including that black exhaust and "heat cover" on it. Pipe it self could be something else, if it look near original... No plates etc...
    What pipe would give more torque? And to be like "4-stroke like" torque?
    @jgr72 I'm sure there's someone on here that straight swapped the dt 200 motor for the 125 no modifications
      jgr72
      Do I need to change whole engine? is it possible to just change cylinder/piston? Or does 200 have longer stroke (different crank)?
      • J jgr72
        @jgr72 wouldn't have a clue mate
        • J jgr72
          About a week ago, I bought new project for me 🙂 My plan and idea is to keep this as original looking as possible, and maybe try to get museum register for it. That's why I'd like to change exhaust to as original look as possible... maybe gianelli painted black!? Now bike is running quite well, and papers claim it has 17kw... I think I will just ride the next summer, and take it to parts during next winter...
          here are few photos:
          @jgr72 Looks nice and tidy, with some minor work she would look mint in no time bud. 😉
            What a gem!
              jgr72
              Thanks 🙂 photos will lie, it's not that good looking IRL, but best that i've have seen for some time... there are some scratses in plastics etc...
              Today, I changed fork boots (progrip, I order them from ebay.co.uk), it was an easy job... Few days ago I changed brake and cluth lever blades, brake was missing the ball on the outer end, and both was wrong color, they should be black and thet ware aluminium-color...
              Next step is to find where it's leaking oil... at least 2t oil tank is leaking, If I'm not able to find new hoses I think I will empty the tank and add oil into the gasoline, and forget the original 2t oil supply system...
              ZrakoZ 1 Reply Last reply
              • J jgr72
                ZrakoZ
                ZrakoZ
                Zrako
                @jgr72 Im changed oil hoses for clear ones from halfords . Cost me like £5 or less.
                1979 Jawa Mustang 50
                2003 Gilera DNA 125 R.I.P
                2015 Keeway TX 125 SM
                2006 Yamaha DT 125 X
                J 1 Reply Last reply
                • ZrakoZ Zrako
                  jgr72
                  How does the 2t oil hose connect to down end (pump side)? Silicone hose might be best... that tightens well and does not leak so easy than harder hoses...
                  • J jgr72
                    ZrakoZ
                    ZrakoZ
                    Zrako
                    5min job . Just reuse the hose clamps or get some from ebay.
                      jgr72
                      wrote on last edited by jgr72
                      Okey you did it that way 🙂
                      Today I struggle with front brake pads... I've seen and changed various brake parts in various vehicles, and never been so hard... I don't know did I do something wrong or am I just stupid 😄 But now it's there... Maybe pad retaining spring wasn't in original shape anymore... I need to take it apart again, cause caliper seals ware so bad condition... Next step is to change rear tyre 🙂
                        jgr72
                        -New fork boots
                        -new levers
                        -new rear tyre
                        Rear turning light apears to be loose 😄
                        New sticer decals, transparent (2t) oil hose and a set of main jets ordered from ebay...
                        3
                        • J jgr72
                          -New fork boots
                          -new levers
                          -new rear tyre
                          @jgr72 Looking good bud - nice work. 👍
                            Yeah that's looking smart.
                            • MightymanM
                              You swapping to new graphics? The current ones you have are awsome!
                                jgr72
                                I'm only changing that are broken or worn... And will replace them to exactly original.
                                MightymanM 1 Reply Last reply
                                • J jgr72
                                  @jgr72 nice 👍
                                    jgr72
                                    Few days ago I changed original snorkel to an DT230 Lanza version... Few decals arrived also from ebay... Not changing them now... later... maybe during winter... If I decide to take the bike in parts and do some painting to body and rear swing...
                                    Been sitting in google for hours and days 😄 ... searching for something fun:
                                    maybe I will change Gianelli exhaust, Athena 170cc cyl kit and mikuni TM30 carburetor during winter... Those shoud give me more pleasure to ride 🙂 And still keep original look... Need to work hard to make the money for that 😄 😄 😄
                                      jgr72
                                      A little update... Today I fixed front brake... Sealing was worn, and it would be only matter of time, when the brake cylinder would stuck totally... It was already a bit lazy I think... I did it just in time, there ware some corrosion in brake caliper, but I used sand paper and decide that it's still useful... Piston was in excellent condition... Old brake fluid was quite black and shitty... perhaps original and nearly 30 years old? Then caliper rebuild with new sealing and gasket... Tomorrow I have to bleed air away from the system... It looks like I have to use pressured air to force brake fluid into caliper... Brake lever is now doing nothing 😄 Sorry that I was too lazy to take any photos...
                                      I found myself from ordering a new carb... Mikuni TM30... and it's on the way already 😛 And earlier I also ordered DT230 Lanza version of carburetor -> air box joint... Lanza item should be direct fit to TM30 carb and maybe some minor modification to the original air box... On the engine side, the diameter difference (VM28 vs TM30) is only 1mm bigger, I assume it will fit to the original intake rubber... TM30 is also 5mm longer, but that shouldn't be any problem...
                                      Anyone have idea for right main jet? 160? 170? 180?
                                      Silocone tubes arrived yesterday, I will replace all 2-stroke oil feed tubes from oiltank, to carb...
                                        jgr72
                                        Today I changed leaking autolube hoses to a silicone one... I ordered them from ebay many weeks ago and they arrived few days ago... It was an easy job to do. Tank to autolube pump hose was nice fit with 5mm silicone hose. Autolube pump to carb was nice fit with 3mm hose. But be aware if you bleed whole pump empty, it might not be able to suck oil from tank!!! Be careful when you start the engine!!! I have to squirt oil direct in to the pump and open air screw in order to get the air out from the pump. Here are from photos from that job...
                                        Dissolution:
                                        Pump to carb hose size:
                                        Tank to pump hose:
                                        Pump to carb hose in place:
                                        Tank to pump hose in place:
                                        Ready to ride:
                                        • J jgr72
                                          Dissolution:
                                          Tank to pump hose:
                                          Ready to ride:
                                          @jgr72 Nice clear lionesis what I like to see.
                                          Keeping an eye on that oil 😉
